I always wondered if this would happen. I had no idea it was out though...thanks for the heads up.
Am i the only one in this forum using blender cam,, its free!
Its GREAT , but i would recommend knowing blender first.
open source , free
Modeled in blenderCAM calculated paths with Waterline paths.
I've been using blendercam for a little over a year now and really like it. I have never used any other CAM package so I don't know what I am missing. I use it daily to design and generate g-code for all of my cnc router projects. Blendercam is far from being perfect but the nice thing I like about blendercam is that its written in Python as an add-on for Blender so its very easy to modify it to fit your needs and to fix bugs.
It did take me a few weeks to figure out how to use it and modify it, but it was worth the time spent learning.
Hello @sherikhalid. I am here to help you if you want good blenders ultimate guide then thebest Blenders by healthplz in 2020 is best.
best dslr stabilizers gimbals are used to add additional support for long, demanding camera shots, as well as adding flexibility and dynamism in your work.
Portable blenders are awesome when it comes to utility, do check this awesome review article about portable blenders.
https://bestportablestuff.com/best-portable-blender/
Previously I started working on PTC CREO 5.0 for designing and modeling purposes. Later on, I have started SolidWorks and now I am planning to learn . Blender CAM is an open source solution for artistic CAM. With the much advanced features, Blender 3D would be my go to choice when I have to built complex 3D objects like CNC cutting paths and fixes. You must contact the support/help section of Blender 3D for the Blender CAM operations.
https://bestportableblenderonline.com
However, I am looking forward to make a 3D model of for my new portable blender.
I quite like Vitamix series blenders https://bestblender2021.us/
I have use many but this one is the best welding helmet
I have also used , It is one of the best welding helmets in the market in 2021.
