GrblGru: Free CAM and 3D-Simulation for mills and lathes - Page 31
Page 31 of 38 FirstFirst ... 2128293031323334 ... LastLast
Results 601 to 620 of 746
Thread: GrblGru: Free CAM and 3D-Simulation for mills and lathes
  1. #601
    Sep 2008
    Default Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    Thanks all for the advice, I am playing around some more and I'm making some progress
    @joerlane
    I do have limits set up for homing as in my pic, I do like homing and am used to it for my mill, I have had to stop programs before and with homing it is allot easier to reposition in the middle of a cycle when need be
    I am using the GRBL Firmware, v1.1h with the mods to the config_h as noted in my post
    @Jay_Perez
    confirm yes on V5.0.0 for GRBLGRU, yes I figured out the 2 viewer, so I think I understand that part now and I am making sense of the CAM process etc.. I tried your recommendation the in simulation mode, so I open the .dxf, put in the variables etc. I 'Set Workpiece Zero Point' here is a screen shot which makes sense
    Attachment 488541
    then I set up the actual position on the Unimat I want as the start point, I switch to "GRBL V1x" and get this, which is not where it is physically notice my actual shown work positions..
    Attachment 488543
    If I then hit 'Set Workpiece Zero Point' in connected mode, I get this, and I can't see the toolpaths? and of course in real life this would be a huge problem!
    Attachment 488545
    I know I am close, it's just not clear to me yet, is there something I am missing?
    @GRBLGRU
    Thank you for your reply and thank you for your research and development of this program, it is definitely interesting and very useful.. keep going!!
    I will take advice for now and not focus too much on the limits, until I figure out what I need to do and until I understand the programming better
    I will send you my email to customize my Unimat, I am not too bad with Fusion360, so I will make a 3D model to match my lathe
    I am a little disappointed about the threading, But I do have a Arduino 2560 so I can and probably will switch over to the GrblHAL system, as you note below for practicality
    Lastly, I am not sure how to fix the attachments, seem to show up for me fine in preview, I apologize I am not sure?
    Best to all, thanks again
  2. #602
    Nov 2016
    Quote Originally Posted by gauthib12 View Post
    Attachment 488543
    Attachment 488545
    I'm also not getting notifications of new posts on this forum. Will have to look into my preferences.
    Sorry but I get an error message when I try to view your attachments.
    Jay
  3. #603
    Sep 2008
    Hello,
    I am trying to see if the picture format is the problem, else any suggestions? Let me know if this one works?
    Attachment 488655
  4. #604
    May 2016
    I still can't open your attachments.
    Things are going wrong here at the moment.
    If you are not logged in, you can not see the last post. You also don't get any notifications on new post anymore.
    I have already informed the administrator about this, but I haven't received any feedback yet.
    Free program download at www.GrblGru.com
  5. #605
    Oct 2010
    Greece
    Default GrblGru Troubleshooting
    Hi there. I installed Grblgru. I have connected arduino mega with ramps and i get to following error. I didn't edit in any way the config file by the way.
    Please help.
  6. #606
    Jan 2016
    Hello, Can anyone tell me if GBRLGRU now supports inch mode?
    I searched but all i could find it had been dropped some years back but they were hoping to bring it back.
    But I can't find it.. looks like a nice program but I would like to be able to use inch mode.
  7. #607
    Sep 2008
    I am trying to repost my post pictures, below I'm confused a bit but I noted two icons in the upper left hand side (cnczone) and (industry arena) my pic show in the latter but not here, it seems the two forums are linked but not for attachments?
    I am using the GRBL Firmware, v1.1h with the mods to the config_h :
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230116_202954-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230116_203041-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230116_203315-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230116_203703-jpg
    @Jay_Perez
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230121_164510-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230121_164539-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-20230121_164601-jpg
    Best,
    B
  8. #608
    May 2016
    Default Re: GrblGru Troubleshooting
    Can you please give us more details about the error.
    What error message is displayed ?
    Which Mega-5X version and which GrblGru version are you using ?
    When exactly does the error occur ?
  9. #609
    May 2016
    @new2cnc
    Sorry to disappoint you. I had the 'inch mode' in older versions, but it was program-technically very complex for me. Therefore I have switched it off for now.
    As long as I am still developing new functions, it will have to stay that way. After that it will be possible.
    @gauthib12
    I will write you an email
  10. #610
    Oct 2010
    Greece
    First it gives me a pop up window error message that says:
    >G10 L20 p1 x0 y0 z0 a0 b0<
    Grbl error:9
    G-code lockedd out during alarm or job state.
    See controller windows for details
    GCode transmition is aborted
    And then in the controller window below it shows the following
    grbl 1.2h ['$' f
    ok
    ok
    [MSG:Caution: Unlocked]
    ok
    Grbl 1.2h ['$' for help]
    [MSG:Check Limits]
    [MSG:'$H'|'$X' to unlock]
    I am using this Mega-5x version
    https://github.com/fra589/grbl-Mega-5X
    The GrblBru V5.0.10
    Nothing occurs
  11. #611
    May 2016
    It looks like you are using a Mega-5X version that does not support all of your axes.
    When installing GrblGru, in the directory Program(x86)\toe\GrblGru xxx
    the file 'grbl-Mega-5X-v1.2d_XYZAB_SPINDLE_PWM_ON_D6.hex' is
    stored.
    Use the program 'XLoader' to flash your Mega-5X controller with this file.
    This provides the axes X, Y, Z, A and B.
  12. #612
    Exclamation Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    There is a problem with the new version beta.
    GRBL 1.1 Lathe mode.
    The 5.0 command line
    ---> 120
    Waiting for Grbl identification ...
    Grbl ready @ COM5
    0 G10 L2 P1 x0 y0 z0
    grbl 1.1h ['$' for help]
    ok
    ok
    [ver:1.1h.20190825:]
    [opt:v,15,128]
    ok
    ok
    Idle|WPos:0.000,0.000,0.000|FS:0,0|Pn:RHS|WCO:0.00 0,0.000,0.000
    Idle|WPos:0.000,0.000,0.000|FS:0,0|Pn:RHS|Ov:100,1 00,100
    The 5.0.14 command line
    ---> 120
    Grbl ready @ COM5, buffer size=120
    0 G10 L20 P1 X0 Y0 Z0
    ok
    ok
    ok
    catch sio fault: Idle|WPos:0.000,0.000,0.000|FS:0,0|Pn:RHS|WCO:0.00 0,0.000,0.000 System.IndexOutOfRangeException: Index was outside the bounds of the array.
    at GrblGru.SioThreadGrbl_1x.DoWork()
    catch sio fault: Idle|WPos:0.000,0.000,0.000|FS:0,0|Pn:RHS|Ov:100,1 00,100 System.IndexOutOfRangeException: Index was outside the bounds of the array.
    catch sio fault: Idle|WPos:0.000,0.000,0.000|FS:0,0|Pn:RHS System.IndexOutOfRangeException: Index was outside the bounds of the array.
  13. #613
    May 2016
    @Diskus
    Thanks for your quick feedback.
    I have just uploaded V5.0.15.
  14. #614
    Member ZeNUMERIC's Avatar
    Jun 2015
    Zenica
    @ GRBLGRU
    I installed version 5.1 with the Mega-5X.I'm trying to make paths for "DragKnife" but the knife doesn't exist in the tool list.
    How is it possible to place DragKnife in the list of tools for practical application?
    Thank you for your attention!
    Screenshots are attached.
    P.S. All praise and congratulations for the genius production of GRBLGRU!
    I will soon publish a translation for Serbian/Bosnian/Croatian language.
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-newpicture023-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-newpicture024-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-newpicture026-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-newpicture025-jpg
  15. #615
    Jun 2015
    Zenica
    I found that version 5.02 has dragknife in the tools list so I will use that version.
    Is it possible to copy the tool list from version 5.02 to 5.10?
    Another question: how is it possible to make your own tool list?
    Greetings!
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-newpicture028-jpg
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-newpicture029-jpg
  16. #616
    Jun 2015
    Zenica
    GrblGru was seen on this forum on 02.01.2023. Has anyone seen him after this date?
    Greetings to all!
  17. #617
    May 2016
    @ZeNUMERIC
    All tools and templates are stored in simple ini files.
    You can edit, copy and delete them with a normal editor.
    You can find the files in the directory C:\ProgramData\toe\grblgru_xxxx\Database.
    The extention of the tool files must be ".tool".
    You can also create a personal file e.g. "MyTools.tool" with your own tools, which you can load from the right mouse context menu.
    In the menu there are also some other functions to edit the tools like "Export to Excel".
    Attached Thumbnails Attached Thumbnails GrblGru: Free CAM and 3D-Simulation for mills and lathes-image-1-jpg
  18. #618
    Member antidesco's Avatar
    Mar 2023
    in last version 5.x of GRBLGRU doesn't include scan functions wright?, is possible obtain oldest versión to work in a lathe copy profiles ?
  19. #619
    Jun 2015
    Zenica
    @GrblGru
    I thank you for your attention and effort.
    Greetings!
  20. #620
    May 2016
    @antidesco
    The whole measuring programs have been revised. There was very little request for measuring on the lathe. Therefore, it has been canceled.
    But if you explain to me what exactly you want to do, I'm sure we can find a solution for that
