GrblGru: Free CAM and 3D-Simulation for mills and lathes - Page 16
Page 16 of 17 FirstFirst ... 61314151617 LastLast
Results 181 to 192 of 194
Thread: GrblGru: Free CAM and 3D-Simulation for mills and lathes
  1. #181
    Registered sivas58's Avatar
    Nov 2018
    Default Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    Arkada??m Muhte?emsin. Böyle bir yaz?l?m? payla?t???n için te?ekkür ederim.
  2. #182
    Feb 2018
    Dominican Republic
    My respect for that leader, the program every day is better, brother blessings
  3. #183
    May 2016
    Release notes V3.35
    On my Dropbox a new version is available for download. bit.ly/2xF1KJ8_GrblGru_Release
    The pocket milling functions were reworked and completed with a StepOver input. Also the production of chamfers is now possible with V-Cutter as well as limited with normal EndMill.
    I will try to make a video about this soon.
    I am especially pleased about the provision of Spanish texts by user DANTRON. He also contributed 2 very nice 3D-models of his self-constructed milling machines. Thanks again for that.
    Have fun with GrblGru
    GrblGru: Free CAM and 3D-Simulation for mills and lathes-pic1-jpg
    Attached Thumbnails Attached Thumbnails GrblGru: Free CAM and 3D-Simulation for mills and lathes-pic1-jpg
  4. #184
    Feb 2018
    Dominican Republic
    Thank you leader for your generosity
  5. #185
    Registered Germinal's Avatar
    Feb 2019
    Hi friends ... I've read all the posts about GrblGru. But there are a few questions I want to ask you. First of all, can GrblGru be used for 5 axis cnc machine? I'm a mechanical engineer and doing a 5 axis cnc project. But I'm not good at programming and software. I made a 3d printer before. For 3d printer; I used the combination of Arduino mega, marlin and repertier. Now, I don't know what combinations to use for the 5 axis cnc. Can I use GrblGru and Grbl for 5 axis cnc? What other software and firmwares do I need to use?
  6. #186
    May 2016
    Looks like we have the same goal.
    I want to extend my program to 5 axes. As hardware I chose the Arduino DUE. As software on the DUE I use the free program g2core.
    There is an old g2core version, which is very promising. (See link below) At the moment I'm trying to get the latest version of g2core up and running.
    GrblGru can already control the 5 axes. So if you create the GCode manually or have finished GCode, you can already use GrblGru in combination with a DUE and g2core.
    But a corresponding CAM functionality for 5 axes ( real 3D ) will still take some time.
  7. #187
    Member Khalid's Avatar
    Apr 2006
    Pakistan
    Wow..cant wait to see the final product...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  8. #188
    Oct 2006
    Hi GrblGru
    How can I specify to drill at center of circles. The tool path is showing at the edge of the circles. Using 3.36.0.
    Also I am trying to route .126" holes with a .125" router but the holes are skipped. Same if I change holes to .130".
    Thanks.
  9. #189
    May 2016
    You're right. The display in the 2D view is a bit confusing. I must change that in the next version.
    If you switch on the display of the calculated toolpath with the toolbar button 'NC' together with the SHFT key, you can see that the drilling always takes place in the center of the circle. (see pic)
    The base for a hole must therefore always be a circle. Could this be the reason for skipping ?
    If not please send me your DXF or SVG file, so I can see where my error is.
  10. #190
    Jul 2006
    Brazil
    I am working on the Brazilian Portuguese translation. I sent a comment on your YT, but dont know if you saw it. Please tell me where I have to send the text file for your appreciation. And many thanks for this excellent work!
  11. #191
    May 2016
    That's great Thank you very much for your help.
    I sent you a PM with my email address.
    Let me know when I can return the favor.
  12. #192
    Activation process carissimi's Avatar
    Dec 2018
    Hello,
    Your dropbox link is not available. Could you check?
    By the way, i made a video explaining your amazing software for brazilian guys:
