Scan a metal part with flat bed scanner into CAD program
Results 1 to 5 of 5
Thread: Scan a metal part with flat bed scanner into CAD program
    Member matridium's Avatar
    May 2008
    Default Scan a metal part with flat bed scanner into CAD program
    Does anyone have experience doing this?
    I have a flat part with 5 holes in it it has lots of curves and instead of trying to use an edge finder and finding lots of points and entering them into a CAD software and interpolating lines is it possible to just use a flat bed scanner to scan the part and then convert it into a DXF?
    Thanks in advanced.
    Mike
    Junior Member vicpaulsen's Avatar
    Apr 2018
    Mineral Wells
    Default Re: Scan a metal part with flat bed scanner into CAD program
    Yes that is very possible. I have done this but lay down two rules in the x and y axis to use as calibration guages. You can import the resulting image into your cad program and then create the various lined. arcs and circles.
    I've use this technique to create flat gasket patterns from castings and it has worked very well.
    May 2008
    Quote Originally Posted by vicpaulsen View Post
    ok so if I use just two steel rules one in the x and one in the y I can use them to calibrate the image? I guess just trace the part with the drawing elements in Auto cad?
    Best
    Mike
    Apr 2018
    Mineral Wells
    Yes that is exactly what I have done. What CAD software are you using?
    Member routalot's Avatar
    Dec 2003
    Is this of any help?Good luck with Inkscape as I find it the least intuitive piece of software ever devised.
