Need Help! STL File?
Results 1 to 8 of 8
Thread: STL File?
    Jan 2012
    Default STL File?
    I have this stl file to make this easy say the image is 2.00 x 2.00 and I what to make it 50% smaller 1.00 x1.00 and remember this is a STL file of a image what can I use and how can I resize or reduce the image size?
    Thanks any help would be great!
    Member jalessi's Avatar
    Feb 2007
    Default Re: STL File?
    Quote Originally Posted by rmachinist View Post
    1: Convert STL to DXF
    2: Scale DXF to desired size
    Have a most awesome evening!
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2012
    Convert 3D STL to DXF scale it and Convert DXF back again to STL to cut it in 3D? and what program can i use for this?
    Feb 2007
    What software did you use to create the STL?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Most CAM software can scale the .stl before creating toolpaths. No changing of formats is necessary.
    UCCNC 2017 Screenset
    Feb 2007
    Quote Originally Posted by ger21 View Post
    I completely agree with what Gerry said, please post information about what software you are using so someone here may provide pertinent information, direction and help.
    Jeff...
  7. #7
    Member awerby's Avatar
    Apr 2004
    When you say this is an STL "of an image" - does that mean you've created a heightmap mesh from a bitmap? Or are you trying to save a 2D image as a STL (which isn't going to work)?
  8. #8
    Jan 2012
    i gotten the STL file from (thingiverse) i have GIBBSCAM v12 , freecad, and fusion 360. i use gibbscam for creating toolpaths any help would be great thanks!
STL File?
STL File?
