Need Help! STL to CAD files
Results 1 to 6 of 6
Thread: STL to CAD files
    Sep 2005
    Default STL to CAD files
    Hey there all,
    I need to find a program if one exists that will allow me to transfer .STL files to a format that will allow a CAD software program to read them. I need it to be IGES, STEP, , etc so I can machine the part that has been converted.
    Anyone know of such a program?
    Any help would be appreciated
    Apr 2018
    Default Re: STL to CAD files
    Turbocad or
    Mastercam.
    Usually your CAM program can import an STL. pretty common format.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    If you are looking to convert the .stl into a solid or surface model, you really can't.Even if you could, it wouldn't be any better than the .stl. That's like turning a pencil drawing into a photo.
    UCCNC 2017 Screenset
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    like Gerry said an STL file is not really a solid. it is made from triangles, it is machinable but won't be smooth
    www.integratedmechanical.ca
    Member awerby's Avatar
    Apr 2004
    You can machine directly from a STL mesh file, if you use a CAM program that can deal with them - DeskProto is one. If it is tessellated too coarsely, you'll see faceting in your machined parts, but if the triangles are small enough you won't. There are "surfacing" programs that let you construct different kinds of geometry over the top of your mesh files, if you really need NURBS or parametric formats, but you'll usually lose some detail when you do that. On the other hand, the new surfaces will be smoother. But if all you want to do is machine the parts, you don't really need to do that.
    Sep 2006
    As mentioned previously, TurboCAD (and possibly many other CAD programs) can import STL files. The scale may be off it it was drawn in mm and loaded in with inches. That is easy to fix. If the object is not smooth enough, then you may have to re-draw all of the surfaces to create a new 3D object that matches the outline of the STL object.
    Steve
STL to CAD files
STL to CAD files
