DXF Files Needed - Subaru Strut Spacers
Results 1 to 7 of 7
Thread: DXF Files Needed - Subaru Strut Spacers
    Aug 2014
    Default DXF Files Needed - Subaru Strut Spacers
    I've searched the internet high and low for these files and have not been able to find them.I have measurements but don't have the skill to design the CAD. Is there anyone that can help?
    Member jalessi's Avatar
    Feb 2007
    Default Re: DXF Files Needed - Subaru Strut Spacers
    Broknindarkagai,
    Post a sketch with dimensions, or a picture if possible.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Aug 2014
    I am trying to make something like the last image. I'm using 2 inch thick HDPE to make 2 inch spacers. Thank you Jeff!
    Note : Measurements are in inches
    Rear Strut Spacer
    DXF Files Needed - Subaru Strut Spacers-rear-jpg
    Front Strut Spacer
    DXF Files Needed - Subaru Strut Spacers-front-jpg
    Example of finished product
    DXF Files Needed - Subaru Strut Spacers-img00365-jpg
    Jun 2008
    Here you go.
    Mike
    Attached Files Attached Files
    Aug 2014
    I'm sorry I should have been more clear. I'm need 3D models. I'm running a Roland MDX-20
    Jun 2008
    Here is the 3D model in Solidworks format. You have to double check model, I am not responsible for dimensional accuracy
    Good Luck
    Mike
  7. #7
    *Registered User* paulitu's Avatar
    Nov 2018
    Quote Originally Posted by Mike 1948 View Post
    Here you go.
    Mike
    Hi Mike, thank you for the file. This is the front one, correct?
    Does anyone have the rear spacer?
    Thank you,
