DXF problem Acad2006
Results 1 to 5 of 5
Thread: DXF problem Acad2006
    Dec 2003
    Mar 2003
    Shelby Township
    Default Re: DXF problem Acad2006
    Somebody is not following the .dxf spec. do you have a copy of Rhino or something else that can open it?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Dec 2003
    I see by other forums AC1021 indicates it originated from a later version of Autocad.
    I tried my trusty convertor using DWG and DXF destination for 2006 and did not work?
    I don't have any other Cad software.
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    did a search for DXF format versions....can up with this link to a autodesk forum post
    a couple of convertor links
    Teigha
    http://autocad-drawing-file-version-...r.winsite.com/
    Mar 2003
    Shelby Township
    AC1021 = AutoCAD 2007
    AutoCAD is very picky about the .dxf file format, and often won't open files that other applications will. I've always found that Rhino would usually open any .dxf's that AutoCAD would not, but I don't have a copy installed right now.
