CNC capability
Results 1 to 4 of 4
Thread: CNC capability
    KimSheard's Avatar
    Mar 2022
    Default CNC capability
    Looking for CNC capability 5x2.5m sheets of plywood, 30mm thick.Has anyone got a profile CNC that could perform the task?
    Member awerby's Avatar
    Apr 2004
    Default Re: CNC capability
    You really have sheets of plywood 5 meters long and 2.5 meters wide? Are the shapes you want to cut out of them really big too?
    Aug 2017
    China
    Omni 2675 Cnc Router Engrave Laker'sLogo To Memory Kobe
    2500*5000mm working area is ok , the only trouble that container inside width is 2300mm , so cnc will be seperate into 3 parts ,then you connect them together by screw .
    so most customer choose working area less 2000mm .
    You can contact with me +8618560201508 or omnisales6@omni-cnc.com
    Member routalot's Avatar
    Dec 2003
    Does the enquiry refer to 5 sheets or 5 metres each sheet?There are a few 3 metreX2metre machines that I know of but 5 metres is out of the ordinary.
CNC capability
CNC capability
