MDF CNC needed in London/ Surrey area
Results 1 to 2 of 2
Thread: MDF CNC needed in London/ Surrey area
    Member voxxonline's Avatar
    Sep 2019
    Default MDF CNC needed in London/ Surrey area
    I need help with cnc'ing two enclosures for my two way bookshelf speaker.
    18 mm mdf.
    Design attached.
    In London, Epsom or whereabouts.
    Thank you
    Attached Files Attached Files
    Member routalot's Avatar
    Dec 2003
    Default Re: MDF CNC needed in London/ Surrey area
    I think you need a bit more help than just the machining of the enclosures.I tried 2 different viewers and couldn't find enough information in the file to understand what it is meant to be.It seems to be just a single piece about 254X150 ish with a few pairs of parallel lines.Could you review the complete drawing and maybe post it as a dxf (ideally R12 format) as not everybody has the version of Autocad you may have used and one of the ways to hook users is to change the file format every version change to "encourage" users to buy the upgrade.The old dxf can be read by almost every CAD system.
