- Planar Wall Profiling troubles
Greetings,
My basic simple novice goal to determine the best Operation for Cookie Cutting some flat shapes from 1/8 Aluminum. I've reviewed 2D Profile Wall without Floor, 2D Profile Wall with Floor also Floor & Wall.
2D Profile Wall w/o Floor...
What is the suggestion for why the Toolpath is not closing while leaving gaps ?
Is it the Engage or Start Drill Point that is causing the Gaps in the Toolpath?
How do I remove the Gaps in the Toolpath? I have circled the Gaps with Green Pencil.
Re: Planar Wall Profiling troubles
Did you try creating a curve and between your objects and use follow curve?
- You may not post replies
- You may not edit your posts
Forum Rules
