step file
Results 1 to 5 of 5
Thread: step file
    Sep 2011
    Poland
    Default step file
    Hello,
    After loaded step or igs file into CAM module, I can't do anything with model.
    Why can't I work with step or igs files in CAM module?
    Best Regards
    Amnon
    Member 1 Infinite Loop's Avatar
    Sep 2009
    U.S.A.
    Default Re: step file
    We need more information about what is happening. When you say you can't work with the model, what is the problem?
    NX
    NX 12.0.2
    May 2014
    Try doing a Wave link from the model and hide the original, this will allow you to select keypoints and apply Synchronous operations. Or, it could be the geometry came in as non-solid. See link for a discussion on the forum.
    Sep 2009
    U.S.A.
    bnagel made a good point. Make sure sure your selection filter is set properly.
    NX
    NX 12.0.2
    Sep 2011
    Poland
    Thank's a lot ...... filter......mmmm what a stupid mistake.
    Respect
    Amnon
step file
step file
step file
