Need Help! Divides the NC program
Results 1 to 4 of 4
Thread: Divides the NC program
    *Registered User* artemnafanya's Avatar
    Sep 2018
    Default Divides the NC program
    Mar 2016
    Poland
    Default Re: Divides the NC program
    Hi
    There is special Custom Command "pb_cmd_tape_break.tcl". All you need to do is to import it.
    Divides the NC program-tape-jpg
    Attached Thumbnails Attached Thumbnails Divides the NC program-tape-jpg
    Sep 2018
    Quote Originally Posted by ncmatic View Post
    Hi
    Hello. Thanks for the answer.
    I knew about this function, but I could not get it to work.
    Perhaps you have an example of a postprocessor using this function, or a detailed description of how to use it?
    Member 1 Infinite Loop's Avatar
    Sep 2009
    U.S.A.
    Another method you can use to split operations is Divide. However, it can only divide an operation by time or distance, not by size.
    NX series 1926, v1942
