UG NXCAM HEIDENHAIN POSTPROCESSOR
Results 1 to 14 of 14
Thread: UG NXCAM HEIDENHAIN POSTPROCESSOR
    Aug 2015
    Default UG NXCAM HEIDENHAIN POSTPROCESSOR
    Aug 2008
    Default Re: UG NXCAM HEIDENHAIN POSTPROCESSOR
    Many of the sample ISV machines in your installation have Heidenhain postprocessors. I suggest you look at those, and choose one closest to what you want, and use it as a starting point in Post Builder.
    For example, look at the in and mm versions in Program Files\Siemens\NX 10.0\MACH\resource\library\machine\installed_machi nes\sim01_mill_3ax\postprocessor\heidenhainTNC\
    Mark Rief
    Siemens PLM
    Dec 2004
    estonia
    Hello
    I do custom post processors. Maybe I can help?
    Marek
    Nov 2016
    Philippines
    Hello Marek,
    Do you have or Can you help me build post processor for bridgeport tnc 370? using nx
    thank you
    Dec 2004
    estonia
    Hi
    Write to me for more information.
    marek.heero@gmail.com
    Member PeterTheWolf's Avatar
    Aug 2008
    Hello,
    I have a working DMG DMU200P MILLPLUS post for a 5-axis Non-orthogonal machine that DMG builds.Would this be of any interest to you?
  7. #7
    Sep 2017
    Finland
    Hello
    Anybody has 3 axis Heidenhain 355/360 postprocesor for nx cam?
    Mika
  8. #8
    Dec 2004
    estonia
    Hi
    I have written a postprocessor for my 3 axis CINCINNATI FTV 840. It has Heidenhain iTNC 530. It might be working also on 355/360.
  9. #9
    Nov 2017
    Greece
    Hello
    I’m looking for postprocessor heidenhain TNC 430 3 axis 5 axis positioning and 5 axis simultaneously for UG NX.
    Thank you
  10. #10
    Registered hell0worla's Avatar
    Jan 2018
    hi
    I’m looking for postprocessor heidenhain TNC 530 for UG NX
    thanx
    fatih-kaan5@yandex.com
  11. #11
    Dec 2014
    I’m looking for postprocessor heidenhain TNC 530 for UG NX pleasce msg
    tnax
  12. #12
    wotong03's Avatar
    Dec 2019
    Smile looking for postprocessor heidenhain TNC 530 for master cam 2018/2019/2020
    hi
    every body,I’m looking for postprocessor heidenhain TNC 530 for master cam 2018/2019/2020?my?machine is table-table.
    and I hove siemens 840d 5axis post for UG NX10, if enyone haven't,?we can?Exchange?it?my e-mail:wotong03@gmail.com,think you!
  13. #13
    Member Zibby76's Avatar
    Mar 2019
    Quote Originally Posted by PeterTheWolf View Post
    Hello,
    Hello, I just have got old DMU machine, could you help me with the postprocessor?
  14. #14
    Aug 2008
    Hello,
    I may be able to help with an NX post.
    Can you send me the model of machine with controller configuration.... and if possible.... a picture of the axis/pallet?
    Thanks,
    PeteW
    Quote Originally Posted by Zibby76 View Post
