Originally Posted by
joeavaerage
what I like about microswitches is that they have a reasonably well defined hysteresis.
With Mach at least, and presumably UCCNC, when an axis is homing it travels towards its home switch, until the switch activates, then decelerates to a stop and then backs up until the switch de-activates.
At that point it zeros the machine coordinates. Thus it is not the position of switch activation but rather the position of switch activation LESS the hysteresis of the switch.
Proximity switches do not have a particularly well defined hysteresis and I found that I could get as much as a 0.1mm variation depending on that hysteresis. With Omron roller plunger microswitches
the hysteresis is quite well defined and even specified. Using such switches I can get 0.02mm repeatability....and that's without index homing, which of course could be an order of magnitude better again,
but at 0.02mm I find it unnecessary.
Craig
