Need Help! NEED HELP! UCCNC Software on Surface Grinder
Results 1 to 3 of 3
Thread: NEED HELP! UCCNC Software on Surface Grinder
    Member BGies480's Avatar
    May 2022
    Post NEED HELP! UCCNC Software on Surface Grinder
    I recently had a Harig 612 Surface Grinder retrofitted into a 3-axis CNC machine. The control on the machine is a M3X system using UCCNC software. The Y-axis moves the wheel up and down, the Z axis moves the table in and out, and the X-axis moves the table left and right.
    I need some help building our first PGM(s). As far as the Grinder goes, I'm only familiar with the Harig EZSurf 1control, which are much different than what we're dealing with now. I do have experience with G-Code programming. I need to develop PGM's for wheel roughing and dressing, as well as a main grind PGM. Any info would be helpful! Thank you!
    Feb 2012
    Usa
    Default Re: NEED HELP! UCCNC Software on Surface Grinder
    Quote Originally Posted by BGies480 View Post
    Aren't the programs you need, G-Code? Or are you needing help with UCCNC?
    May 2022
    Yes, the PGM's I need are G-Code. I'm still learning the UCCNC software but have plenty support as far as that goes.
