quick question
Results 1 to 5 of 5
Thread: quick question
    Activation process neilb's Avatar
    Jul 2018
    Default quick question
    sorry in advance it's probably been said a thousand times.
    i have my axis set up and working, just dialing in the configuration in UCCNC.
    my question is how accurate is accurate?
    if i ask the mill to move 30mm (units set as mm) it moves 29.9992
    is that close enough? i would like it to move 30mm if i ask it to. am i expecting to much?
    thanks neil
    ps. sorry if posted in the wrong section
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: quick question
    Hi Neil - If you change the DRO settings to 0.00mm units you will probably get 30.00mm (but this maybe not how far it actually moves, its just the theoretical movement) . But its the size of the job that matters! Is the resulting part 30.00mm? Peter
    Jul 2018
    Quote Originally Posted by peteeng View Post
    hi Pete, thank you for the reply.
    I zero'd the DRO and that said 29.9992, it was a basic straight line so no actual part made. I think I will mill out a square and measure that and report back.
    thanks neil
    Jul 2018
    ok so i got the mill to move 30mm in the X direction and 30mm in the Y direction to basically mill a square slot .5mm depth of cut, i took a pic of the screen after each move, then measured the resulting square.
    not even close to what i was hoping for lol, obviously i have some tuning to still do
    Attached Thumbnails Attached Thumbnails quick question-20210701_184025-jpg   quick question-20210701_184126-jpg   quick question-20210701_184254-jpg   quick question-20210701_184709-jpg
    quick question-20210701_184751-jpg
    Jul 2018
    i spent some time today trying to fine tune it, i put the drill chuck in the mill along with a piece of tig welding wire sharpened to a point. i bent the wire to 90 deg so it could point along a ruler so i could count off the mm moved. i set it to move 100mm in the Y axis, and after a few runs managed to get it to move 100mm and the DRO was reading 100. i then copied the steps value into the X axis config tab and repeated the same test, and confirmed that also moved 100mm and read 100 in the DRO.
    obviously without machining a part and measuring it i don't know how accurate it is, so that is next
quick question
quick question
