Enable limits during homing UCCNC UB1
Results 1 to 4 of 4
Thread: Enable limits during homing UCCNC UB1
    Member torcher's Avatar
    Dec 2020
    Default Enable limits during homing UCCNC UB1
    When homing the signals from the limit switches are not considered.
    Is there a way to enable this?
    Reason is I'm doing a upgrade of an old mill which has +/- limits separate from home switches (located some 1/3rd between limits). If the machine is on "wrong" side of home at start up, it can crash during homing procedure.
    Ideally hitting a lim during homing should make the direction change to reach home signal.
    I could solve this by using the lim as home, but thought I might ask for other solution first. Having home 1/3rd between limits makes homing faster with less transport.
    Im using UCCNC with a UC300eth UB1.
    Jan 2018
    United Kingdom
    Default Re: Enable limits during homing UCCNC UB1
    That's an interesting issue. You'd think the machine would know which side it was on and move accordingly. ie: the shortest direction back to home without going near a limit switch.
    I have no solution for you but I am updating to the 300 and uccnc soon too.
    I'll have a good read through all the uccnc stuff tonight and see if there is anything mentioned for a resolution.
    Dec 2020
    Thanks.
    Before homing the machine has no clue as to where it is, at least not on such a system (steppers with encoders "hybrid servos". The direction for homing can be set, but that does solve the problem.
    Dec 2020
    Threadlift of the week, I know but still; no input for a better solution enabling the lim sw during homing?
