New Machine Build Should I just GET IT DONE!!!
Results 1 to 4 of 4
Thread: Should I just GET IT DONE!!!
    Jan 2018
    United Kingdom
    Default Should I just GET IT DONE!!!
    So. I'm going to get this damn machine fully finished this year even if it kills me!. Get all the switches fitted.
    Get the X ballscrew sitting more level (it pulls the table down to one side as it moves by as much as 0.15mm).
    Get that lovely 1.8kw servo fitted.
    I'm a little tired of Mach3 and Win XP (even though it works perfect) and really considering UCCNC for a change.
    CNCDrive Shopping list as follows:
    UC300eth - 5lpt.
    2x UCBB dual port boards with all cables
    1 extra UCSB single port board +cable
    Extra IDC26 to DB25 cable
    Analogue cable IDC16 to DB15
    UCCNC itself.
    Should cover all eventualities
    Prob £400gbp ballpark once imported
    Ouch!!
    Then on top of that. A plain DB25 board (is for input pins so may need optoisolation, yes??). And a DB15 plain breakout board for analogue 0-10v.
    To fit on din rail.
    Anything I've missed??
    Should I just GET IT DONE!!!-p1030927-copy-jpg
    Attached Thumbnails Attached Thumbnails Should I just GET IT DONE!!!-p1030927-copy-jpg
    Member routalot's Avatar
    Dec 2003
    Default Re: Should I just GET IT DONE!!!
    Of course you could just take care of that X ballscrew issue,install LinuxCNC and start making stuff.Which would cost very little and if you ran the software from a memory stick,you could revert to the old setup in a couple of minutes and with no annoying table movement.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    You can't use all the pins on these with a UC300ETH.
    The UCBB requires one standard port and one "input" port.
    The UCSB requires one standard port.
    That would require 3 standard ports and two "input" ports.
    The UC300ETH has two standard ports, and three "input" ports.
    If you want to use all 5 ports, maybe one UCBB, one UCSB, and two cnc4pc C10D's?
    https://www.cnc4pc.com/bi-directiona...face-card.html
    Or something like a UB1 with UD1 daughterboard.
    UCCNC 2017 Screenset
    Oct 2004
    Checkout the C94 for this machine:
    https://www.cnc4pc.com/c94-multifuntion-board-b.html
    Arturo Duncan
    https://cnc4pc.com
