Any other details in the message?
Do you get the message immediately?
My guess would be AV software blocking it?
I am trying to install uccnc version 1.2048 on a desktop computer running windows 10. When I double click the setup file I get a message saying this app will not run on this PC. I have been running it on a laptop window 10 with Gerry's 2017 screenset without any problems. Not sure what's going on. Does anyone have a solution to load this on my desktop. Thanks Jim
UCCNC 2017 Screenset
The only other thing it said was check with software company for a version that will run on my computer. The message pops up immediately. I tried version 1.211 and it looked as though it was going to work. I didn't complete the install. I later found a copy of 1.2049 and tried it and it worked. I went ahead and loaded it and set everything up. Haven't run a file yet but everything seems to be working fine. I assume there is very little difference between 1,2048 and 1.2049. Thanks Gerry. I'll check into the AV possibility. Thanks for the reply
Jim
Are people sure it's not just the .Net framework causing it?.
Can be finicky with some versions.
Even on newer pc's that are supposedly up to date, it wants you to go backwards and install ver 4.0
Sometimes it will not tell you!.
