UCCNC tangent backstep?
Results 1 to 7 of 7
Thread: UCCNC tangent backstep?
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default UCCNC tangent backstep?
    Hi All - I use UCCNC CAM for profile work. Sometimes when doing circles or arcs it puts a little backstep at the tangent. Can't seem to get it to happen on purpose or set it up so it does not happen. Any clues? Peter
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: UCCNC tangent backstep?
    Do you have backlash comp enabled?
    UCCNC 2017 Screenset
    Jul 2018
    dum dum
    Hi Gerry - No compensation on, just checked it. I Import dxf from Rhino3D. I have played with the dxf settings but it happens occasionally. Happens to anybody else? Peter
    Mar 2003
    Shelby Township
    I haven't heard of this from anyone else.
    WHat are you using for cam?
    Jul 2018
    dum dum
    Hi Gerry - For profiles or simple pockets I use the CAM in UCCNC. If I use visualcam it does not do it. When UCCNC generates the code you can zoom in on the toolpath and see it. So I just made a circle in rhino, divided it into two arcs. Checked it in rhino and it doesn't have any invalid lines or "tails: then exported it in dxf (then opened ther dxf in rhino to check its OK which it is) then in UCCNC it puts the tails on the arcs when generating gcode, see image. Then I did the process again and it didn't do it!! Lucky to capture it. Peter
    Attached Thumbnails Attached Thumbnails UCCNC tangent backstep?-arc-jpg   UCCNC tangent backstep?-backstep-jpg
    Mar 2003
    Shelby Township
    Then it's an issue with the way the UCCAM works.
    I've never used it, as I could not create any .dxf files that it would even load.
  7. #7
    Jul 2018
    dum dum
    Hi Gerry - I've used dxfs from lots of sources and never had an issue, interesting. If the jobs simple its easier to do in UCCNC then muck about in mechcam, import G code etc etc. I usually split arcs into polylines in the dxf settings in rhino. This sidesteps the arc "tail" issue. I'll soldier on... Peter
