- Need Help!- High Precision Automatic Tool Sensor Cnc Z Axis, How to wire to UB1 Controller UCCNC
hello,
Looking for help to Setup 4 wire automatic tool sensor to UB1. I seen people on Youtube with it setup on UB1, UCCNC Software. Didn't show how it was setup/connected.
The only wiring i found was on google.
Not sure if it apply to this probe, or perhaps they the same.
Would appreciate all feedback
thanks
User avatar
lloxley016
Reason: add more info
Re: High Precision Automatic Tool Sensor Cnc Z Axis, How to wire to UB1 Controller UC
Hi, gotten this to work ? I use this one quite similar, just with chip blowoff.
Hi, what i did is that i just connected the override limit to the pins, and then i have connected that pin to reset in UCCNC, i belive it's code 152 on pin setup
Sent fra min SM-G975F via Tapatalk
Did this configuration work for you?:
"Yellow wire / => assuming it's ( Probe Single )
Green Wire /=> assuming it's ( Probe Return Single )
Red wire /=> 24v + Resistor 2k 1w
Black wire /=> Either ( COM- ) or ( 0V ) Or Connect Green wire to ( COM-) + resistor"
Did you connect the overtravel circuit to the OSSD safety circuit on the UB1?
- You may not post replies
- You may not edit your posts
Forum Rules
