Need Help! Intermittent Issue With Z Probing Direction - UCCNC & UC300ETH-LPT5
Results 1 to 4 of 4
Thread: Intermittent Issue With Z Probing Direction - UCCNC & UC300ETH-LPT5
    Aug 2017
    Default Intermittent Issue With Z Probing Direction - UCCNC & UC300ETH-LPT5
    Using a CNCRouterParts PRO4848, I recently converted from the standard Smoothstepper/Mach3 to UCCNC and the UC300ETH-LPT5 with UCCNC Screenset 2017. I'm using the probing macro supplied in this thread...
    https://www.cnczone.com/forums/cnc-r...-software.html
    Conversion was fairly uneventful and everything initially work very well. A few weeks ago, I was measuring tool length using "Auto Zero Initialize" and the tool started moving upwards. I checked all the setting and confirmed that nothing changed. Restarted UCCNC with no change. Shut down and restarted everything and still had the same problem. I needed to cut a project , so I just set the Z-workpiece manually. Everything cut fine, so I'm sure it's strictly a probing based issue. When I tried again a few days later, probing worked as expected. Well it happened again yesterday and I'm scratching my head. Any ideas?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Intermittent Issue With Z Probing Direction - UCCNC & UC300ETH-LPT5
    So, it worked fine for a while, and then started going backwards?
    Did anything change in your system?
    Do you by chance have a CNC Drive pendant? A small number of people with these pendants have had issues with the probing macros.
    I don't believe I've ever heard of this happening to anyone.
    The way the probing works, is the macro first reads the Z axis DRO. It then subtracts the Firs Probe Distance, and tells the machine to probe to that position. So it should always probe downwards.
    When it's moving up, is the Z axis DRO value increasing?
    Do you ever have any other issues with Z axis direction? A bad connection on the Z axis dir wire could possibly cause this.
    Can you post a screenshot of the Auto Zero settings, and the run screen DRO's when you start to probe?
    UCCNC 2017 Screenset
    Aug 2017
    Quote Originally Posted by ger21 View Post
    ...Do you by chance have a CNC Drive pendant? A small number of people with these pendants have had issues with the probing macros....
    Thanks for the reply Gerry. I really like your Screenset.
    Yes. I am using a VistaCNC iMach3 P4-S. I hadn't thought of this as a possible cause. I do use the pendant to move to the tool measurement position. Have you seen any resolution to the probing macro when used with a pendant?
    DRO values work as expected.
    Mar 2003
    Shelby Township
    Try disabling the pendant plugin and see if the probing will then work correctly. Restart UCCNC after disabling the pendant.
