UC300 ETH-UB1
Results 1 to 6 of 6
Thread: UC300 ETH-UB1
    Default UC300 ETH-UB1
    Hello Gents
    I am trying to connect the NPN type proximity sensors to the X,Y and Z axis.
    These NPN sensors operate from 6 V to 36 VDC.
    I was informed that these sensors can be connected to both the high 24V and the low 5V?
    If I power the sensor up with 24V and activate the sensor, by moving a metal object, to the contact point, the voltage drops to 0,8 V.
    The schematic, which comes with and on the sensor, shows a resistor between the black and brown wires. I remember doing this on my MACH3 BOB and had to achieve around 5 V, when the sensor was activated. This was also with a 24VDC supply.
    I`m just confused on how to connect it to both the 24V and 5V? This does not make sense to me and then a resistor can not be used at all, between the BLK and BRN wires.
    Regards
    Craig
    Default Re: UC300 ETH-UB1
    I forgot to mention that these sensors are NO and not NC.
    Regards
    Craig
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    11a on Page 13 of the UB1 manual
    UCCNC 2017 Screenset
    Hello Gerry
    Yes, I did see that in the schematic, but I was not sure about the resistor, which goes between the BRN and BLK wires on the sensor? I was under the impression that a resister is compulsory, or else the BOB will be damaged?
    So If I power the sensor from my 24 V PSU and connect the BRN wire to POSITIVE, then the BLK wire must go to one of the X103 - X115 inputs and the BLU wire must go to the 0 V terminal on the BOB?
    Thank you for responding.
    Regards
    Craig
    Mar 2003
    Shelby Township
    It only shows a resistor if using PNP sensors on an NPN input.
    The schematic in the manual shows brown to PS 24V, black to X103-X115 (or X210-X215), and blue to 0V on the UB1.
    I'm far from an electronics expert, so can't offer any more than that.
    Thanks Gerry
    I will connect them like that.
    Regards
    Craig
UC300 ETH-UB1
UC300 ETH-UB1
