No, there is no line limit to UCCNC.
Arturo Duncan
https://cnc4pc.om
Does anyone know if there is a line limit to UCCNC?
I tried doing some dynamic milling which produced a lot of lines of G-Code for a fairly simple operations, but when I tired to do a few simple things together UCCNC refused to load the code.
I had to break the operation up into smaller operation files to be able to do it.
Now I am using an old POS (Point Of Sale) machine that is running Windows XP, so it probably isn't the gruntiest of PCs. Is it a limit of the software or a limit of the PC?
This is one of three pieces I needed to break it up into to get it to load.
The other thing is once it was loaded and I tried to jog, it took ages to respond to the command. Like several seconds.
- Stepcraft 840 stuck axis limit switch UCCNC issue
- Need Help!- losing a line of movement when running a gcode - uc100 + uccnc (wich leads to drops)
- Need Help!- SolidCAM line, arc, rapid G-code in every line
- Need Help!- How to make Mach3 go line by line in the g-code?
- Need Help!- way to see the g code comands visualized line by line in Bobcad?
If my post is missing the n't you might have to mentally add it yourself.
Arturo Duncan
https://cnc4pc.om
Older version I think are memory lmited, but there's no hard line number limit.
The newer 64 bit versions can handle millions of lines of code.
UCCNC 2017 Screenset
Thanks guys. I am in the middle of building a new stand with another PC that supports 64 bit / Win7. So hopefully that sorts out the issues.
