WHB04B-4 and UCCNC???
Results 1 to 8 of 8
Thread: WHB04B-4 and UCCNC???
    May 2014
    Default WHB04B-4 and UCCNC???
    Hi All,
    I know UCCNC supports the XHC-HB04 pendant, but has anyone tried the WHB04B-4 with UCCNC?
    Same manufacturer just a few more options. Now I understand that the new options may not currently work, but do any of the XHC-HB04 options work?
    Just would prefer to buy a newer pedant with the hope that one day the newer one will get full support, over buying the old one and finding the new one is then supported and have to buy another pendant.
    TIA
    If my post is missing the n't you might have to mentally add it yourself.
    Oct 2004
    Default Re: WHB04B-4 and UCCNC???
    As far as I know, there is no plugin for it. I do not think CNCDrive is going to write a plugin for it since they have the new UCR201.
    We do have a few of the older UCR200 that we are trying to rid of as it an obsolete product:
    https://www.cnc4pc.com/ucr200-wirele...g-pendant.html
    Arturo Duncan
    https://cnc4pc.com
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I don't think it will work at all. And as Arturo said, CNC Drive will not be writing a plugin for it.
    UCCNC 2017 Screenset
    May 2014
    Thanks guys I'll just stick to the XHC-HB04 then since it has a few more macro options.
    Member picposter's Avatar
    Nov 2019
    Just a Info for you guys:
    https://www.forum.cncdrive.com/viewtopic.php?f=14&t=2449
    Here is a working Plugin for uccnc with the WHB04B-4 and -6 Version.
    My WHB04B-6 works really Well. Some Bugs with jogfeed, but easy to handle.
    Try it Out. I am pretty Happy with it.
    Cedric
    May 2014
    Quote Originally Posted by picposter View Post
    https://www.forum.cncdrive.com/viewt...hp?f=14&t=2449
    Cedric
    I wound up buying a XHC-HB04, but will keep this in mind as a future option.
  7. #7
    Member Makcoll's Avatar
    Feb 2023
    Cedric
    I can’t get this to work. Is there some kind of wizardry I’m missing?
  8. #8
    Member dgentile's Avatar
    Mar 2023
    Quote Originally Posted by Makcoll View Post
    I have the WHB04B-4 and it works quite well.
    However initially I had the dongle connected to the front facing USB ports of my computer... and whilst the dongle would connect to the pendant (all it requires for that is the 5V USB Power to the dongle...) The Plugin for the WHB04 would NOT find the thing.
    On a whim I decided to put the dongle in a different (rear end) USB port - and it recognised it instantly... and has been working without issues ever since.
    I can't explain WHY it would make a difference... but try a different port and hopefully you get lucky.
