What do you stand to gain by running 50hz over 25hz?
But I was running 50kHz or 100kHz with the UC100, although... I am now using a ribbon cable I wasn't once using. I wonder if that is a problem?
I am still waiting on confirmation that the UB-1 is still the ducks guts of BOBs to go for (within reasonable price range). I have another cheap one here I could try.
If my post is missing the n't you might have to mentally add it yourself.
That says nothing about what your drivers will handle...
For the record, I have to run 25kHz with my UC300eth. But my machine runs awesome.
Well I know they handle at least 50kHz because they have been running like that for probably the last 5 years.
For ****s and giggles I tested ger21's theory that the PC will have no bearing on the frequency. And he was 100% correct my laptop made zero difference. Which brings it back to being a BOB or cable issue.
Seeing that I did one further test... What if the BOB was starting to play up and that was the reason for my UC100 loosing connection? You would think it was USB related going off the message, but plenty of program writers are crap at writing error messages.
So I put the UC100 back in the system and tried running it at 50kHz like it was previously running. Nope didn't want to know about it. So I backed it off to 25kHz and it ran fine. So I finished doing a test cut that I was in the middle doing when I finally had enough. It seemed to run fine.
Which leads me to the conclusion that perhaps there is nothing wrong with the UC100, just that it was no longer happy to run at the higher frequency.
This would lead me to the breakout board or drives, not the UC100.Which leads me to the conclusion that perhaps there is nothing wrong with the UC100, just that it was no longer happy to run at the higher frequency.
Both the UC100 and UC300ETH work at 25Khz, but not higher frequencies.
I've never heard of any controller not being able to run at all of their available frequencies, and you think you have this issue with both?
UCCNC 2017 Screenset
It's not just about wiring it is also how you have it protected Do you have a Power Filter for the VFD Drive do you have a Power Filter for any switch mode Power supplies this is where most of the noise comes from and the EMI Power Filters will take care of that
Here is a suggestion for your VFD Drive Input Power Filter this needs to be mounted close to the VFD Drive TDK Lambda RSEN-2030L you can use the same for any power supplies just lower amperage rating
Correct Ground of you system is also vey important
Mactec54
Designing is nearly done. I plan to section the PSUs and the drivers from each other with a divider wall. The wall will go between the 200mm fan and the 120mm fans.
At the moment I am leaning towards putting the VFD on the back wall so I can feed the display / VFD control panel into the same board as the touch screen monitor.
Been back to the drawing board. I have a sheet of 5mm aluminum here I was planning to use for another project but it never happened (CNC bed). I can mount all the drivers and PSUs on it and run a ground strap from the VFD to the ally plate. The PC PSU I would probably leave isolated since the only connection between the controller and the PC will be a network cable. Would need to investigate EMI power filtering.
You have a Star Point, Grounding in any Machine Build all main Grounds connect to the same point this can be a Bus or a stud, Shield Grounds attach direct to the Ground Plane which is you Grounded mounted Plate
The EMI Power Filter is mounted close to the VFD Drive, Main power going to the VFD Drive Plus Ground is connected to the Filter and then out to the VFD Drive, the Power Filter I already posted the best type of Filter to use, this has been used by lots of builders on the Zone with 100% success if installed correctly
Mactec54
Can you do me a drawing of what your talking about? I thought by having all the drivers and the PSUs on the same aluminum plate they automatically connected to the same point where the VFD comes off. It sounds like you are saying I should have every driver and every PSU, plus the VFD all ground to one central point???
Shielding like on the cables?
I think I may have a EMI power filter already on the system. I needed a IEC socket so I am pretty sure I bought one of these https://www.jaycar.com.au/iec-emi-po...6-amp/p/MS4003
Jaycar also has these https://www.jaycar.com.au/240v-ac-emi-filter/p/MS4001
Do I need more? Which type? Where would I put them?
Just ordered two 967-RSEN-2030L
