M6 macro z height issue when changing from short to long tool
Results 1 to 2 of 2
Thread: M6 macro z height issue when changing from short to long tool
    Dec 2016
    Norway
    Default M6 macro z height issue when changing from short to long tool
    Hello.
    I'm running a M6 macro with a fixed plate for tool length measurement.
    I have a problem when I change to a longer tool than I originally was using. After the tool change the machine tries to go up to z0 as if it was the shorter tool which is above the set limit (limit is z0.1) for the z axis and then stops.
    If i manually lower the z after the error and try again it works. The program goes to z0 before the tool change and the machine is rerunning from the last point after the change.
    Can you help me what is wrong with this code? I've found the code on the forum and just did some changes for it to work for my machine, but cant really figure out this problem with the new z height.
    If i manuall lower the z after the error it works.
    Code:
    //M6 Macro for automatic tool measuring.  First the machine moves to the tool change position, then to the fixed plate
    //to measure the new tool length
    double ToolChangeX = 10;      //Tool change X position (all in machine coordinates)
    double ToolChangeY = 2.5;      //Tool change Y position
    double ToolChangeZ = -0.1;    //Tool change Z position
    double FixedPlateX = -368.99;    //Fixed plate X position (machine coordinate)
    double FixedPlateY = 363.99;    //Fixed plate Y position
    double CaFixedPlateZ = -100;    //Fixed plate ca. Z position
    double SafeZ = -0.1;        //Safe Z in machine coordinates
    double ZRetractHeight = 20;      //Height above Z0 to which probe will retract
    double CoarseRate = 500;     //Feedrate for initial probing
    double FineRate = 10;          //Feedrate for fine probing
    double Zmin = -125;         //maximum probing distance
    double PlateDifference = exec.GetCpos();    //Fetches the plate difference from the C axis DRO
    // G91 Sets incremental mode,
    // G90 Sets absolute distance mode
    // G53 Sets move in absolute coordinate for that line
    int originaldistancemode = exec.actualdistmode; // remember the distance mode
    int originalmodalmode = exec.actualmodal; // remember the modal mode
    exec.Stopspin();    //Turn off spindle
    exec.Code ("G91");    //sets incremental mode for the whole macro
    double XOriginalPos = exec.GetXmachpos(); // Get the current machine coordinates
    double YOriginalPos = exec.GetYmachpos(); // Get the current machine coordinates
    double ZOriginalPos = exec.GetZpos(); // Get the current machine coordinates
    exec.Code ("G53 G00 Z" + ToolChangeZ);    //Moves to tool change position
    while (exec.IsMoving ()){}
    exec.Wait (200);
    exec.Code ("G53 G00 X" + ToolChangeX+ " Y" + ToolChangeY);    //Moves to tool change position
    exec.Wait (200);
    MessageBox.Show ("Press OK when toolchange is complete");
    exec.Wait (200);
    exec.Code ("G53 G00 X" + FixedPlateX + " Y" + FixedPlateY);    //Move to Fixed Plate Position
    while(exec.IsMoving()){}
    exec.Wait(200);
    exec.Code("G53 G00 Z" + CaFixedPlateZ);    //Retracts Z for move to plate
    exec.Wait(200);
    exec.Code("G31 Z" + Zmin + "F" + CoarseRate); // Probe Z quickly to get rough height
    exec.Wait(200);
    exec.Code ("G00 Z" + 0.4); // Retract 0.2mm above the plate
    exec.Wait(100);
    exec.Code("G31 Z" + Zmin + "F" + FineRate); // Probe Z slowly for better resolution
    exec.Wait(200);
    //because we stopped at the fixed plate, we now want to update our DRO to the value of the plate difference
    exec.mainform.sumoffsetcontrol1.G54.newCzinput(PlateDifference);  // Set G54 to new Zzero
    exec.mainform.sumoffsetcontrol1.G55.newCzinput(PlateDifference);  // Set G55 to new Zzero
    exec.mainform.sumoffsetcontrol1.G56.newCzinput(PlateDifference);  // Set G56 to new Zzero
    exec.mainform.sumoffsetcontrol1.G57.newCzinput(PlateDifference);  // Set G57 to new Zzero
    exec.mainform.sumoffsetcontrol1.G58.newCzinput(PlateDifference);  // Set G58 to new Zzero
    exec.mainform.sumoffsetcontrol1.G59.newCzinput(PlateDifference);  // Set G59 to new Zzero
    exec.Code ("G53 G00 Z" + SafeZ);    //retracts Z
    exec.Wait(100);
    exec.Code ("G53 G00 X" + XOriginalPos + " Y" + YOriginalPos);    //moves to original XY position
    exec.Wait(100);
    exec.Code ("G90");  //returns machine to absolute for Z move and rest of code
    exec.Code ("G00 Z" + ZOriginalPos);
    exec.Wait(100);
    exec.Code("G" + originaldistancemode); // Set system back to the original distance mode
    exec.Code("G" + originalmodalmode); // Set system back to the original distance mode
    Dec 2016
    Norway
    Default Re: M6 macro z height issue when changing from short to long tool
    Think I found it.
    Edited this line:
    To
    double ZOriginalPos = exec.GetZmachpos(); // Get the current machine coordinates
    And them removed these lines so the program start running at safe z height:
    exec.Wait(100);
    Works so far. But if it is right I'm not sure
    Code:
    exec.Wait (200);
    exec.Wait (200);
    exec.Wait (200);
    exec.Wait(200);
    exec.Code("G53Z" + CaFixedPlateZ);    //Retracts Z for move to plate
    exec.Wait(200);
    exec.Code("G31 Zmin + "F" + CoarseRate); // Probe Z quickly to get rough height
    exec.Wait(200);
    exec.Wait(100);
    exec.Code("G31 Zmin + "F" + FineRate); // Probe Z slowly for better resolution
    exec.Wait(200);
    exec.Wait(100);
    exec.Wait(100);
    //exec.Code ("G00 Z" + ZOriginalPos);
    //while(exec.IsMoving()){}
    //exec.Wait(100);
    exec.Code("Griginaldistancemode); // Set system back to the original distance mode
    exec.Code("Griginalmodalmode); // Set system back to the original distance mode
