The UCCNC runs in demo mode only without a license key.
Read point 1.6 of the UCCNC manual: http://www.cncdrive.com/UCCNC/UCCNC_usersmanual.pdf
Hi, some of you may know, I've been building my own CNC Machine since September, after the initial teething problems I encountered and advice from people on here I've managed to get it built. It's now all wired up (temporarily) just so I can test it out, however, I've come across a problem with the Axbb-e and UCCNC program not linking up together, I followed the instructions that came with the Axbb-e to get it connected up to the Network and when I do the 'Test Connection' on the Ucxxx Utility it says everything is working, but the 'Blue' link light on the Axbb-e only ever flickers during the UCCNC Splash screen while it's loading up, then it goes off...?
I will say, I'm only using the Demo version of UCCNC because I wanted to test it 1st then if I get it working I will buy the license... Or, do I need to get the Licence for it to Link up in the 1st place...
Cheers
Phil
