Thank you. Mr Robertspark helped me to fix my problem.
The Solution is here: http://www.forum.cncdrive.com/viewtopic.php?f=11&t=2268
I will make a tutorial in german soon.
Greets Markus
Hello!
I have posted the same question also in cncdrive forum. Maybe the community here is a bit bigger.
I would like to implement my Mach3 Pedant in UCCNC. But i dont know the sytax and the functions.
The MPG Works for one axis, also Set Zero on all axis. But i would like to change the axis with one button.
See here, its the same post as in cncdrive :
hi everybody,
in my old Mach3 times i worked on a jog pendant, which i will use also in uccnc.
My set up: UCCNC --> UC400ETH --> Stepper BoB
My question is if i can change the Axis to X,Y,Z with one button?
Maybe you can help me with my problem.
MPG works, but only for one Axis...
I would like to have a
SET Button --> Change from Code 220 to 221 to 222
ZERO Button --> SET Active Axis Working Zero
HOME Button --> Active Axis Homing
OUTPUT 1 --> X Axis Active (LED)
OUTPUT 2 --> Y Axis Active (LED)
OUTPUT 3 --> Z Axis Active (LED)
In Mach it works with Macros, but i dont know if it works also in UCCNC.
Maybe you can help me a bit?
I made the Pendat with this tutorial from Gerhard Günzel. (See also the Codes at the Page).
http://www.emagu.de/Mach3-Handrad.htm
Maybe you can help me a bit,
thanks very much.
Markus
Greets Markus
