Originally Posted by
originalsigns
Thank you for the reply - I went to the Configuration/General Settings and noticed that the Safe Z height (Units) is set to 25. Does that mean 25", or what does that mean? I tried to set it to 3, but it just jumps back to 25. Do you have any suggested settings, I don't have Limit Switches and I really don't know understand what all these settings are. OHHH, I just noticed right under that in the HOMING SEQUENCE box. Can I just turn off the Z so it won't raise it up? Or will I run into the same problem with the X & Y trying to go off the table? Thank you again!
