First thing I'd try is remove the pendant plugin, and see if you can jog with the keyboard.
Also note that UCCNC does not have a lathe mode, so is probably not the best choice for a lathe. Especially for a beginner.
Hi there...i picked up a used sherline cnc lathe 4410 + rotary table with a computer UCCNC installed, a UC100 dongle and a sherline stepper motor controller. It also came with a imach 3 p4s pendant.
As per my title, I am a total newbie. I have used the lather manually for the last couple of months but now would like to use the cnc element to manufacture prototype parts.
Everything seems to be working. I can move the 3 axis with the pendant and UCCNC using the step control.
However the continuous mode does not work and I can only move each axis step by step if the step size is very small (0.001) and I increased it slowly. If I move the pendant wheel too fast, the stepper motor does not follow. The same happens if I move each axis with uccnc. It only works if I select step and step size of 0.001 and I pause between the steps.
I was wondering if you would have any idea of what is wrong.
- Need Help!- In need of some serious help! Total newbie!!!
- Another total Newbie
- Newbie- Ok I'm a total Newbie
- Need Help!- total newbie
- total newbie
UCCNC 2017 Screenset
