The PC and the UC400ETH can never have the same IP address it would be an IP conflict if 2 devices on a network having the same IP address.
DHCP means dynamic IP when the server (computer or router etc.) gives and assigns IP addresses to the network devices.
If you will use direct connection to the computer then just follow the UC400ETH manual about setting it up. The manual shows everything.
