Need Help! uccnc not smooth running.
Results 1 to 14 of 14
Thread: uccnc not smooth running.
    Feb 2017
    Estonia
    Default uccnc not smooth running.
    hello, i have problem with uccnc,
    my cnc tont run smood on wery simple contour.
    https://gyazo.com/e82f5f4b0f9ca09243ae0e169ba07bb4
    On red circle cnc stops very vast and then almost immediately starts moving again.
    what can cause this thing.
    in attachment is also 2 gcodes there are 9 details all of them ar tooing same litle stopp on same place.
    used fusion 360 to generate gcode.
    Attached Files Attached Files
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: uccnc not smooth running.
    UCCNC can sometimes have issues with transitions to/from arcs.
    Increasing acceleration or decreasing feedrate can help.
    Using all G1 straight segments can also run smoother and faster sometimes.
    CNC Drive is planning on writing a new Trajectory Planner, and will address this issue then.
    UCCNC 2017 Screenset
    Feb 2017
    Estonia
    Quote Originally Posted by ger21 View Post
    When this planner update arrives any idea?
    I have acceleration on 900mm/s2
    And cuting feedrate 3500mm/s
    Rapids are 10000mm/s
    This is very anoing behavior.
    In picture is my diy cnc
    Attached Thumbnails Attached Thumbnails uccnc not smooth running.-dc4ea7d6-f20f-4627-a803-84fab060ebfa-jpg
    Mar 2003
    Shelby Township
    Probably at least 6-12 months. They haven't started working on yet, that I'm aware of.
    Can you set your accel higher?
    Have you tried increasing the error tolerance settings?
    Jun 2015
    Sweden
    Set you CAM software to generate lines (G1) instead of arcs (G2/G3) and then all the path will be lines and should be no more problem.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    I agree with Olfcnc - export your dxf from fusion as polylines of a suitable length and this issue will clear up. UCCNC does have a glitch with arc ends occasionally that I have not been able to resolve. Only strategy has been the polylines. Peter
  7. #7
    Feb 2017
    Estonia
    how I can set it up in fusion 360 ?
    I want to try this one.
    Maybe I can get higher acceleration something 1500 maybe but this is max i think.
  8. #8
    Mar 2003
    Shelby Township
    You may need to edit the post.
    I found this info?
    https://forums.autodesk.com/t5/hsm-p...s/td-p/6095167
  9. #9
    Feb 2017
    Estonia
    okay thanks, i think I can try this one on weekend.
    anything else i have to change ?
    If I replace arcs with lines is the contour smoothness is affected ?
  10. #10
    Jul 2018
    dum dum
    Yes if you pick a big line length. I typically use 1mm or 1.5mm for the polyline length. Peter
  11. #11
    Feb 2017
    Estonia
    so situation where I need 10mm hole with 6mm endmill will result some 8 corner hole ? i dosent seems weary professional
  12. #12
    Jun 2015
    Sweden
    Quote Originally Posted by janis93 View Post
    Huh, what are you talking about?!
  13. #13
    Mar 2003
    Shelby Township
    Circles should cut just fine with arcs.
    If you used line segments, you'd use about 100 for a hole, not 8.
    You shouldn't see any difference in your finished parts when using G1 moves vs G2/G3 moves.
  14. #14
    Feb 2017
    Estonia
    okay, I try to mod post.
    it has to wait some time i cant go to where is my cnc about 2 weeks.
    but if to test cutting and comparison I will get back with results.
