New AXBB controller - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: New AXBB controller
  1. #21
    Feb 2012
    Default Re: New AXBB controller
    Quote Originally Posted by ger21 View Post
    Separate 5V and 24V supplies are best, as the grounds needs to be isolated from each other.
    I asked here:
    forum.cncdrive.com • View topic - AXBB power supply question
    Stepper motors need their own power supply, that connects to the drives. Depending on the drives, it's usually 48V-60V, but can be 24V-36V for smaller motors.
    DMM DYN4 drives are AC drives, and do not need a power supply.
    Clearpath and DMM DYN2 are DC drives, and do need a power supply.
    Totally clear. Thank you.
  2. #22
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I just ordered a couple cheap Meanwell DIN rail supplies on Ebay. I'll test when I get them to make sure there's isolation between them.
    UCCNC 2017 Screenset
  3. #23
    Jun 2015
    Sweden
    I have a few power supplies lying around in my garage. I will have to find a 24Volts one though. so far I only found some 5Volts ones which I can use.
    Are those meanwells real ones or fake chinese ones? Do you have a link? Maybe I will have to order a 24 Volts one.
  4. #24
    Mar 2003
    Shelby Township
    Even the real ones are Chinese, so how do you know??
    I bought these.
    https://www.ebay.com/itm/112196248990
    https://www.ebay.com/itm/122214347202
  5. #25
    Jun 2015
    Sweden
    I bought these.
    Thanks for the links.
    Meanwell is Chinese company? I did not know.
  6. #26
    Mar 2003
    Shelby Township
    Headquarters in Taiwan.
    https://www.meanwell.com/about.aspx
  7. #27
    Jun 2015
    Sweden
    I always thought that Meanwell is a US company but I see now that they are Taiwanese.
    They are close to China so they probably manufacturing things in China and then you can not know what is real and what is fake.
  8. #28
    Jun 2015
    Sweden
    Wanted to order the 24V power supply a few minutes ago, but the ebay seller on your link does not ship to Europe at all.
    I will have to find another listing.
  9. #29
    Sep 2005
    Indonesia
    Hi guys,
    How to wire fifth axis with AXBB-E ? I plan to build 4 axis machine with dual drive Y slave A. Have somebody here tried one ? Do I need to add another BOB ? Do you think it is better to purchase UC300ETH with 5 axis BOB ?
  10. #30
    Sep 2005
    Indonesia
    Please erase ... sorry
  11. #31
    Jun 2015
    Sweden
    Yes my router's gantry is with dual motors. It is controlled with a UC100 though not with a AXBB-E but the AXBB-E also has master/slave axis relations option in the UCCNC just like how the UC100 has that.
    I think you can use any of the isolated outputs of the AXBB-E to control a 5th axis and then no need to add an extra BOB or you can add one if you want.
  12. #32
    Apr 2014
    The AXBB has a plus port also. You can connect there a BOB (UCSB or HDBB2 or any other cards) and you have more 12 outputs and 5 inputs. Above the low quality motor drivers most of them have opto-isolated inputs, so you can use non-isolated outputs to drive the motors.
  13. #33
    Jun 2015
    Sweden
    Same question came up in another topic, it was about the G540. You can hook up a G540 to the port#3 of the AXBB-E and add 2 more drives to the AXBB-E outputs to have 6-axis.
  14. #34
    Oct 2004
    Yes, you can hook up a G540 to LPT3 of the AXBB. Or any other parallel port type controller. You can assign the pins freely in UCCNC and soon in the Mach3 plugin. You can also use different types of breakout boards as long as you use pins 2-9 as outputs. The M26 12 relay breakout boards goes great with it:
    https://cnc4pc.com/m26d-12-relay-expansion-board.html
    If you need a bunch of relays.
    Arturo Duncan
    https://cnc4pc.com
  15. #35
    May 2013
    Hey guys,
    I connected 5v only to my AXBB just to test the connection to UCCNC. I have tried on both my desktop and Microsoft Surface Pro 3 (with USB to ethernet adapter) and get the same issue on both.
    The UCxxx_utility just shows blank. If I disconnect the ethernet cable, it actually says it can't find it. But when connected, it's just blank. I see the blue link light flash on the AXBB every time I hit scan.
    I'm using with an ethernet cable crossover adapter too, since it's a direct connection. I've tried without it also.
    Here are my settings:
    New AXBB controller-axbb-connection-jpg
  16. #36
    Oct 2004
    You need to use UCCNC development version 1.2019 or above:
    https://cnc4pc.com/faq/article/what-...ith-the-axbb-e
    Arturo Duncan
    https://cnc4pc.com
  17. #37
    Oct 2004
    You need to power the board with +24vdc. Can you ping the board?
    Arturo Duncan
    https://cnc4pc.com
  18. #38
    May 2013
    Quote Originally Posted by arturod View Post
    Arturo Duncan
    https://cnc4pc.com
    Thank you, that worked. Sorry I had missed that part. I had downloaded UCCNC before purchasing the AXBB to check it out.
New AXBB controller
New AXBB controller
