Pull apart
Time changes everything. Here it comes, a small footprint all-in-one mini PC which able to run Mach3 and UCCNC. It takes a small CPU resource. The price of this PC is around 100usd include Windows 10.
Weerasak.
www.CNCRoom.com
Pull apart
Weerasak.
www.CNCRoom.com
Do you have full specifications and availability?
Thanks,
HarryE.
I purchased it from Shopee online store in Thailand. I believe you can buy it in your local online store also.
https://shopee.co.th/Z85-Z-8350-2-GB...713.1604291030
Here is the specification.
Z83 II Intel Atom Mini PC 4K UHD
-Win 10 64bit System
-2GB DDR3+32GB eMMC
-Intel Atom x5-Z8350
-Intel HD Graphics 400 Desktop PC
-USB3.0 USB2.0 HDMI Double Wifi 1000Mbps/LAN BT4.0
Weerasak.
www.CNCRoom.com
Nice. What machine is it?
Do you have more videos of it?
It is fixed column CNC milling for soft metal cutting. We designed and made it for our own use.
We prefer big bathtub rather full cover. This helps to collect splash cutting oil back to pump. It also collects cutting chip or prevents fly away chip.
This topic is intended to show current Atom technology which related to CNC things.
Weerasak.
www.CNCRoom.com
Does UCCNC run good on it?
UCCNC 2017 Screenset
I tried this mini PC with UCCNC on the first day when received this PC. Since then I don't have a chance to try it with UCCNC again.
It seems that the Windows 10 keep updating or adjusting itself for the first few hours. The video shows that the CPU graph is jumped up and down before I start UCCNC software. I believe that UCCNC wouldn't consume much CPU time. However, I will check and confirm it again.
Weerasak.
www.CNCRoom.com
Is that .Net package good for Win10? On Win8 or Win10 you should install .Net 3.5 in the "Turn Windows features on or off" window by selecting .Net 3.5. Just press Start and type "optionalfeatures". It will download the proper package.
Thankyou, I will do it properly
It seems to me, we are living in a strange world. Because I thought that LattePanda is using ARM CPU. However, after searching and found that it's using the same CPU Intel Cherry Trail Z8350 and run on Windows 10.
https://www.lattepanda.com/products/1.html
Weerasak.
www.CNCRoom.com
