Newbie Need help with proximity switch setup
Results 1 to 9 of 9
Thread: Need help with proximity switch setup
    Registered healinhand's Avatar
    May 2018
    Default Need help with proximity switch setup
    Mx4660, uc100. I’m trying to setup proximity switches, I guess I’m just retarded. I go to the axis setup page, put in the pin #, hit enter, apply settings and the entry goes back to 0. Any help would be much appreciated
    Oct 2004
    Default Re: Need help with proximity switch setup
    Make sure you have a licensed version of UCCNC and you are not working in DEMO mode. Test inputs, to confirm you have communication OK.
    Arturo Duncan
    https://cnc4pc.com
    May 2018
    Quote Originally Posted by arturod View Post
    Arturo Duncan
    https://cnc4pc.com
    Green and blue lights on, jog working fine
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    The port and pin number you are using is probably an output pin.
    UCCNC 2017 Screenset
    May 2018
    Quote Originally Posted by ger21 View Post
    I guess I m really lost. The PIN number I’m trying to use is the PIN number on the 4660
    Mar 2003
    Shelby Township
    What port and pin numbers are you entering?
  7. #7
    Feb 2012
    Usa
    Is the demo version limited for controlling outputs?
    Sent from my SM-T813 using Tapatalk
  8. #8
    Apr 2014
    You also have to select port 1 when setting a pin. Input pins are 10, 11, 12, 13 and 15. The UCCNC zeros the port and pin if you enter an invalid port/pin pair, or try to assign an input pin to output function or vice versa.
  9. #9
    Apr 2014
    Quote Originally Posted by healinhand View Post
    I checked the MX4660 manual. It sees the world form inside. When you connect something to its input, you have to check the DB25 (CN1) table to find that which output connects to your input. So, you connect output pins to inputs and vice versa... (E.g.: if you connect your proximity sensor to input 1 on MX4660 then its output is pin 10 on CN1, so in UCCNC you have to set port 1 pin 10.)
