Sact - Spindle RPM not displaying?
Results 1 to 2 of 2
Thread: Sact - Spindle RPM not displaying?
    Oct 2017
    Default Sact - Spindle RPM not displaying?
    I have UCCNC hooked up to a 2.2kw (WC) & HY VFD through an eth300-UB1. I am using the UB1's analog output (0-10vdc) and the UB1 onboard relay. The spindle is working as it should (I think).
    My question is that I think I should be seeing an RPM # showing in the Sact box on the run tab? I am in the process of trying to compare what UCCNC says it is sending vs what the VFD says it is doing to make sure my setup is configured correctly.
    I have tried issuing s12000, S18000, ect...
    The spindle speed changes as it should, just no display in the Sact box.
    Thanks,
    Rick
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Sact - Spindle RPM not displaying?
    UCCNC doesn't know what the actual speed is, unless you feed it an index signal from the spindle.
    UCCNC 2017 Screenset
