- Cannot get C22M1 to work with UCCNC
Has anyone used the C22M1 modbus mpg interface (from CNC4PC) with UCCNC?? I cannot get this mpg interface to work properly
I get very unstable jogging with this interface which always ends up with the selected axis in a unstoppable runaway mode until it contacts a limit switch or I hit the reset.
I am working in inches, I thought maybe there are some settings in UCCNC that need be set for inches but I do not see any settings for this, no settings in the C22M1 plugin either.
Any ideas or thoughts would be greatly appreciated.
Re: Cannot get C22M1 to work with UCCNC
Jim,
The current configuration support only metric. You are using a setting in imperial. I am creating a new installer for imperial. We have had a rough day here with issues in our website after an update. But we have to have this maybe tomorrow.
Thanks for you patience.
Arturo Duncan
Welcome to CNC4PC
What is the status on the installer for imperial??
- You may not post replies
- You may not edit your posts
Forum Rules
