I don't remember the exact steps but know that it is clearly described in the manual. Anyway, every time you make a change you need to save it.
I moved my CNC to another PC so I took configuration and copied to new pc. It works fine but the problem is that I have to manually load this configuration EVERY time I start UCCNC . I tried to load it, save it atc. But its allways starts with "Default config"...
Does anyone know how to make it load my config by default upon start?
https://www.youtube.com/c/AdaptingCamera/videos
https://adapting-camera.blogspot.com
Add the /p switch to the target in the shortcut to point to the profile you are using.
UCCNC 2017 Screenset
/p profilename worked like a charm.Thank you
