- $dimexo error
$dimexo error
Hello, I apologize for my total lack of knowledge here,however, I am hoping for a solution. I have a Stepcraft 840 running the latest ver. of UCCNC and when I try to load a dfx. file (from different sources) I will get an error which reads: error reading line 122 (line numbers vary of course) $dimexo. When I look at it in edit mode the $dimexo command is on a different line and the actual error line reads a different command. I would think there is a common factor because of the similar errors. Thanx.
- $dimexo error
- You may not post replies
- You may not edit your posts
Forum Rules
