UCCNC help for acceleration?
Results 1 to 6 of 6
Thread: UCCNC help for acceleration?
    Aug 2014
    Default UCCNC help for acceleration?
    Hi all,
    Im using UC100 with UCCNC. When I make parts (aluminum) the surface finish is not that good (i see like ripples) in the acceleration regions. Slow acceleration kinda solve the problem. I usually do Roughing with high acceleration and finishing with slow acceleration. Is there anyway to add a M-code or something in the Gcode file to change the acceleration automatically for roughing and finishing passes?
    Thanks.
    Aug 2014
    Default Re: UCCNC help for acceleration?
    Anyone please?
    Member vmax549's Avatar
    Oct 2005
    Lady Lake
    If you asked over at teh UCCNC website you may get a bit of help.
    (;-) TP
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Not that I'm aware of.
    UCCNC 2017 Screenset
    Oct 2005
    Lady Lake
    You are not teh only one that has asked for that. Yes it can be done.
    (;-)TP
    Aug 2009
    Netherlands
    My opinion is when you use a low accelaeration then you are not cutting enouph material . In the start your feed is to low .. and you are not cutting at all, so i think you have te speed up. and try constand velocety.
