Huanyang VFD Macro/ Plugin - Page 29
Page 29 of 29 FirstFirst ... 1926272829
Results 561 to 568 of 568
Thread: Huanyang VFD Macro/ Plugin
  1. #561
    Mar 2010
    America
    Default Re: Huanyang VFD Macro/ Plugin
    Quote Originally Posted by -Robert- View Post
    Hi all,
    I used the hyplugin12 and got both the actual rpm as well as the actual current (and of course was able to control the speed). After updating to the latest version of UCCNC and hyplugin14, I do not get any feedback from the vfd, yet the plugin says it can read the vfd settings and it can actually control the spindle.
    What makes me wonder is that I also get no "Current XXX" data in the VFD Status box of the plugin and I do not receive data under "Data Received" - see attached screenshot.
    Using a HY VFD, latest UCCNC, standard screenset and a Wiznet WIZ108SR RS485 to ethernet converter.
    Kind regards,
    Robert
    Huanyang VFD Macro/ Plugin-hyplugin14-jpg
    Hi Robert,
    I can see your connected but oddly no readings in VFD Status.
    Make sure your using the HY14 net2 version I uploaded, the original had some problems, Also I made the mistake of renaming plugin to"HYplugin14" so it won't write over old plugin, so make sure all other HYplugin versions are deleted from the UCCNC plugin folder and 2 aren't running.
  2. #562
    Feb 2009
    Dan 911 can you post a link to the latest plug , I have a issue where 5% of the time when executing a manual toolchange and the code issues a M5 the spindle does not stop , UCCNC turns off water cooling pump so I believe it is executing the code properly . Seems to only become a issue since updating to the latest software , the cure is to manually turn on the spindle via uccnc and then turn off , I believe I am using HYPLUGIN14
  3. #563
    Jan 2018
    Germany
    Quote Originally Posted by Dan911 View Post
    Hi Robert,
    Hi Dan,
    thanks for helping me.
    I am using (and to make sure, replaced again) the plugin with the version from forum.cncdrive.com • View topic - Huanyang Plugin.
    UCCNC
    Software version: 1.2111
    Firmware version: 1.0340
    API version: 2.1790
    Is it correct to assume that as the "VFD Settings" are displayed, there was some feedback from the VFD? With the old version, I also got amps and revs so the VFD is capable of that.
    Kind regards,
    Robert
  4. #564
    Jan 2018
    Germany
    Hi Dan (and all),
    I got some further insights. Sending "01 03 01 08 F1 8E" (stop) at 9600 8N1 through a terminal program results in the VFD to return "01 03 01 00 F0 48", so I guess the communication is working. Sending "01 03 01 11 30 44" results in the spindle turning and "01 03 01 11 30 44". After sending stop, VFD returns "01 03 01 08 F1 8E". Moreover, I had it working with a previous version of hyplugin. So something has changed very likely on the plugin side - is it more picky with respect to timeouts or something? Is the CRC calculated different?
    Kind regards,
    Robert
  5. #565
    Jan 2018
    Germany
    Hi all,
    is the Plugin (v12, v14?) working with the latest UCCNC for everybody else?
    Kind regards,
    Robert
  6. #566
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I recently moved, and can't do any testing. Unfortunately, I haven't seen Dan post anywhere for several months.
    UCCNC 2017 Screenset
  7. #567
    Member SiemonB's Avatar
    Jun 2019
    Quote Originally Posted by ger21 View Post
    Yeah.. sadly :/
  8. #568
    Oct 2016
    Hello,
    I got my Spindle runing using the setup Peter Passuello,CNCNUTZ, describes in his video, UCCNC - episode 148.
    Seems to work ok except commanded speeds are incorrect.
    I get
    Command Speed
    S10 600
    S20 1200
    S50 3000
    S100 6000
    S200 12000
    S250 15000
    S300 18000
    S400 24000
    S16000M03 3750
    Using
    UCCNC 1.2111
    Stepcraft Screenset
    Huanyang HY02D223B, 2.2kw, 8.5 Amp, water cooled spindle.
    RS485
    HYPLUGIN ver 10
    Any suggestions on what I might not have set correctly?
