Huanyang VFD Macro/ Plugin - Page 42
Page 42 of 46 FirstFirst ... 3239404142434445 ... LastLast
Results 493 to 504 of 542
Thread: Huanyang VFD Macro/ Plugin
  1. #493
    Jun 2015
    Sweden
    Default Re: Huanyang VFD Macro/ Plugin
    I think that if the multimeter will show the voltage fluctation depends on the time period of the fluctation.
    If it fluctates fast then the multimeter will likely to show the avarage voltage instead of the numbers moving up and down.
    The 0-24000 RPM if that is the RPM range for the 0-10V input voltage then 1Volt is 2400 RPM and 1000 RPM fluctation is about 0.41 Volts.
    That should be seen on a multimeter if measured on the proper low voltage range and if the voltage is moving slowly enough.
    But if the voltage is changing fast then the multimeter might not show it is why it is better to measure this with an oscilloscope that will show everything.
    It can be that the voltage is really stable but the RPM is still fluctating but that definitely point out a fault of the VFD.
  2. #494
    Mar 2003
    I have a video on Youtube that I did last year. The voltage reading on the meter does not change at all, and the RPM will constantly fluctuate, +1000, then -1000. As I said, it takes over 30 seconds for the 2000rpm change, and the voltage is steady the entire time.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #495
    Jun 2015
    Sweden
    30 seconds is a long time. It is likely a VFD problem. But it is also possible that the carrier frequency of the PWM is close the same as the VFD sampling frequency and is a high frequency.
    If the frequency is high the multimeter will not show the fluctation.
    The VFD is measuring in periods and that always shift only a little bit on the PWM so the measured sum voltage and the RPM changes slowly as the measurement slowly walks through the PWM period.
    Without measuring it with an oscilloscope this will remain only a theory though.
    Another thing to try is to change the PWM frequency to see if it makes any difference but that will also likely to give results which could not lead to a final consequence.
  4. #496
    Oct 2017
    Denmark
    Quote Originally Posted by OlfCNC View Post
    If the voltage is stable on the analog input of the VFD and the motor RPM is fluctating then the problem is with the VFD, but there is one question that the voltage is really stable?
    How did you measure it? With a multi meter or with an oscilloscope?
    I measured it with a voltmeter.
  5. #497
    Mar 2003
    The breakout board converts the PWM to the 0-10V, so the VFD never sees the PWM signal?
  6. #498
    Jun 2015
    Sweden
    Quote Originally Posted by ger21 View Post
    Yes but how well does it convert the PWM?
  7. #499
    Mar 2003
    If the multi meter says the voltage is stable, and never changes at all, doesn't that mean it's pretty good?
    My voltage was always accurate to within .01 volts, at any rpm range, and was 100% stable. But the RPM was never stable.
  8. #500
    Jun 2015
    Sweden
    No, because the multimeter shows only one value which is based on measuring a period of time and avaraging that and the time is usually long.
    You can have for example a PWM with 50% dutycyle 0-5 Volts and high frequency which your multimeter will show as a 2.5V DC voltage, because it samples and avarages.
    In regards the analog voltage for the VFD it is possible that the breakout board converts the PWM to analog inperfectly leaving some fluctation on the signal, for example a 4.5V signal with a 1Vpp fluctation on it.
    If the frequency of that fluctation is high enough then your multimeter might not show it to you, but an oscilloscope is.
  9. #501
    Oct 2017
    Denmark
    Hi All of you
    Just to inform you, I purchased a new VFD, it was completely plug and play, I did the settings, and ran UCCNC with the allready configured plugin, the spindle rotates rock solid at all given RPM settings.
    Thank you all for your support, and a special thumps up for Dan for making this awsome plugin.
    Regards
    Jan
  10. #502
    Mar 2010
    America
    Quote Originally Posted by Tyknok View Post
    Hi All of you
    Regards
    Jan
    Hi Jan,
    Your update is very appreciated but unfortunate China stuck you with a bad VFD. I'm sure very little conciliation to you but your bad experience read here can help others.
    Thanks,
    Dan
  11. #503
    Registered gene8522's Avatar
    Oct 2010
    Hi Dan911,
    PM Sent.
  12. #504
    Oct 2015
    Hi Dan great plugin and thanks for all your hard work, I have it running in uccnc and the 2017 Screen set. I do have 1 question and that is when I increase my speed with either the plus symbol or the slider it maxes out at 18000, my max is set to 24000 for a 2.2kw water cooled spindle. I can s command it to 24000 and it goes there so I'm just wondering if that's normal. Thanks in advance!
    Best Regards,
    Bob
