Huanyang VFD Macro/ Plugin - Page 34
Page 34 of 42 FirstFirst ... 2431323334353637 ... LastLast
Results 397 to 408 of 502
Thread: Huanyang VFD Macro/ Plugin
  1. #397
    Mar 2003
    Default Re: Huanyang VFD Macro/ Plugin
    Dan,
    Have you updated the plugin for the new 64bit version of UCCNC?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  2. #398
    Mar 2010
    America
    Quote Originally Posted by ger21 View Post
    Dan,
    There is no immediate need to update for latest UCCNC version 1.2103... HY12 works fine. Had problems with 1.2102 due to the .NET4 implemented but was fixed in newest UCCNC version. The only update needed for any older plugin is to compile with anyCPU and HY12 was. I only tested in demo mode but will test on machine today.
    Dan
  3. #399
    Mar 2010
    America
    Quote Originally Posted by blaiseb View Post
    Oh! ok!!! Wow! You’re all over the place! I will give ModBusEZ a try!
    I’ll keep you posted!
    Many thanks!
    - Blaise
    The settings for the GT series is in manual so your setup should go smoothly.
    Dan
  4. #400
    Mar 2003
    Oh, I didn't realize that you were already using AnyCPU. Thanks..
  5. #401
    May 2013
    Hi Guys,
    I've just purchased UCCNC and the 300eth to replace my MACH3 configuration, as well as the 2017 screenset. Having done so, I installed the latest HYPLUGIN.DLL with some success. With the initial installation on 2017, the spindle would not turn on. I loaded MACH3, which was already able to turn the spindle on, and it worked as I expected. I loaded UCCNC/2017 again, and the spindle would start but I could not control the speed with the slider. I don't remember if an "s10000" command changed the speed or not :-( I loaded the default UCCNC screenset, reconfigured HYPLUGIN, and it worked. Went back to UCCNC/2017, nothing. Went back to default, nothing.
    help? any clues?
    Many thanks,
    Rick Van Norman
  6. #402
    Mar 2003
    In the 2017 Screenset, you need to change the field number of the RPM DRO from 870 to 2451.
    As for the slider, it was probably due to the commanded rpm being too low. The slider will not increase the speed above the commanded rpm, unless you edit the slider parameters.
  7. #403
    May 2013
    Thanks Gerry!
    That exactly fixed my problem. It wasn't clear that the RPM DRO value needed to be changed.
    Is that only to make this work under the 2017 screenset?
    Thanks again!
    rick
  8. #404
    Mar 2003
    The screenset was created before DRO 2451 was added to UCCNC. At some point, the plugin was changed to require the 2451 DRO (Overridden RPM).
    The plugin wont work in any screen that doesn't have DRO 2451.
  9. #405
    May 2013
    Aaarrrggghh!
    As previously noted, I did get the system working.
    Mostly.
    About half the time, the spindle doesn't turn on. Seemingly randomly. Then, just as randomly, it turns back on.
    Just now,
    1. restart windows
    2. start UCCNC
    3. issue S10000
    4. press "spindle cw (m3)". led came on.
    5. nothing.
    6. press "spindle cw (m3)" again. led went off
    7. repeat 3 to 6 several times with different speed values. nothing
    8. open device manager to make sure windows had not re-assigned com port. it hadn't
    9. open configure plugins, and view the settings for HYPLUGIN. all looks same as previous and just fine
    10. try to turn spindle on again;
    11. WORKS.
    12. on and off, works.
    13. HELP!?!?
    Any notions or ideas about how to debug it?
    Thanks,
    rick
  10. #406
    Mar 2010
    America
    Quote Originally Posted by red6rick View Post
    Aaarrrggghh!
    Mostly.
    Just now,
    1. restart windows
    2. start UCCNC
    3. issue S10000
    5. nothing.
    11. WORKS.
    13. HELP!?!?
    Thanks,
    rick
    Certainly sounds like a connection problem.
    Upload your pro file for profile used and a link to the RS485 converter your using and will try to help narrow down to where your problem is.
    Dan
  11. #407
    May 2013
    Quote Originally Posted by Dan911 View Post
    Dan
    First, let me mention that the hardware (serial adapter, computer, etc) has not changed since I was using this under MACH3. No failures there ever.
    My current profile is attached, as are the driver details.
    Thanks!
    rick
    JBtek USB to RS485 Converter Adapter ch340T chip 64-bit Window 7 Supported
    by JBtek
    Link: http://a.co/6kkpggQ
    Huanyang VFD Macro/ Plugin-driver1-png
    Huanyang VFD Macro/ Plugin-driver2-png
    [Screensetsettings]
    mainscreenfilename=2017
    splashscreen=0
    [axessettingscontrolX]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=4
    Steppinnegate=True
    Dirpinnumber=5
    Dirportnumber=1
    Dirpinnegate=True
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=12
    Limitminuspinnegate=False
    Limitpluspinnumber=12
    Limitpluspinnegate=False
    Homepinnumber=12
    Homepinnegate=False
    Homedirectionpositive=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=60
    Homingspeeddown=30
    Stepsperunit=1527.88745
    Velocity=600
    Acceleration=10
    Softlimitpositive=49.5
    Softlimitnegative=0
    Backlashenable=False
    Backlashdistance=0
    Slaveaxis=None
    Homeportnumber=1
    Limitminusportnumber=1
    Limitplusportnumber=1
    Compaccel=1200
    [axessettingscontrolY]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=6
    Steppinnegate=True
    Dirpinnumber=7
    Dirportnumber=1
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=13
    Limitminuspinnegate=True
    Limitpluspinnumber=13
    Limitpluspinnegate=True
    Homepinnumber=13
    Homepinnegate=True
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=60
    Homingspeeddown=30
    Velocity=600
    Acceleration=10
    Softlimitnegative=0
    Backlashdistance=0
    Slaveaxis=A
    Homeportnumber=1
    Compaccel=240
    [axessettingscontrolZ]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=2
    Steppinnegate=True
    Dirpinnumber=3
    Dirportnumber=1
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Homepinnumber=12
    Homepinnegate=False
    Homedirectionpositive=True
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=39.996
    Homingspeeddown=19.998
    Stepsperunit=6400
    Velocity=199.98
    Acceleration=10
    Softlimitpositive=0
    Softlimitnegative=-6
    Backlashdistance=0
    Slaveaxis=None
    Homeportnumber=1
    Compaccel=240
    [axessettingscontrolA]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=8
    Steppinnegate=True
    Dirpinnumber=9
    Dirportnumber=1
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=15
    Limitpluspinnumber=15
    Homepinnumber=15
    Homepinnegate=True
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=60
    Homingspeeddown=30
    Velocity=600
    Acceleration=10
    Softlimitnegative=0
    Backlashdistance=0
    Homeportnumber=1
    Compaccel=240
    [axessettingscontrolB]
    Axisenabled=False
    Stepportnumber=0
    Steppinnumber=0
    Steppinnegate=False
    Dirpinnumber=0
    Dirportnumber=0
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=0
    Limitpluspinnumber=0
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=24
    Homingspeeddown=12
    Stepsperunit=0.0001
    Velocity=120
    Acceleration=4
    Softlimitpositive=100
    Softlimitnegative=-100
    Backlashdistance=0
    Homeportnumber=0
    Limitminusportnumber=0
    Limitplusportnumber=0
    Compaccel=240
    [axessettingscontrolC]
    Axisenabled=False
    Steppinnumber=0
    Stepportnumber=0
    Steppinnegate=False
    Dirpinnumber=0
    Dirportnumber=0
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=24
    Homingspeeddown=12
    Stepsperunit=0.0001
    Velocity=120
    Acceleration=4
    Backlashdistance=0
    Homeportnumber=0
    Compaccel=240
    [Spindlesetupsettings]
    IsSpindleinPWMMode=True
    SpindlePWMoutpin=0
    SpindlePWMoutpinnegate=False
    SpindlePWMdirpin=0
    SpindlePWMdirpinnegate=False
    SpindlePWMfrequency=200
    SpindlePWMminpercent=0
    SpindlePWMmaxpercent=100
    Spindlesteppin=0
    Spindlesteppinnegate=False
    Spindledirpin=0
    Spindledirpinnegate=False
    Spindlestepsperunit=500
    Spindleacceleration=200
    Spindleminvelocity=8000
    Spindlemaxvelocity=24000
    Spindlerelaysenabled=False
    M3relaypin=0
    M3relaypinnegate=False
    M4relaypin=0
    M4relaypinnegate=False
    M3ondelay=12000
    M3offdelay=10000
    M4ondelay=8000
    M4offdelay=10000
    Floodmistrelaysenabled=False
    M7relaypin=0
    M7relaypinnegate=False
    M8relaypin=0
    M8relaypinnegate=False
    M7ondelay=0
    M8ondelay=0
    M9delay=0
    SpindlePWMoutport=0
    SpindlePWMdirport=0
    Spindlestepport=0
    Spindledirport=0
    M3relayport=0
    M4relayport=0
    M7relayport=0
    M8relayport=0
    EncoderApin=0
    EncoderAport=0
    EncoderBpin=0
    EncoderBport=0
    Encoderreversedirection=False
    EncoderPPR=400
    Pulleyratio1=1
    Pulleyminvel1=1
    Pulleymaxvel1=1
    Pulleyinuse=1
    Pulleyratio2=1
    Pulleyminvel2=1
    Pulleymaxvel2=1
    Pulleyratio3=1
    Pulleyminvel3=1
    Pulleymaxvel3=1
    Pulleyratio4=1
    Pulleyminvel4=1
    Pulleymaxvel4=1
    Pulleyratio5=1
    Pulleyminvel5=1
    Pulleymaxvel5=1
    Pulleyratio6=1
    Pulleyminvel6=1
    Pulleymaxvel6=1
    Pulleyratio7=1
    Pulleyminvel7=1
    Pulleymaxvel7=1
    Pulleyratio8=1
    Pulleyminvel8=1
    Pulleymaxvel8=1
    Pulleyratio9=1
    Pulleyminvel9=1
    Pulleymaxvel9=1
    Pulleyratio10=1
    Pulleyminvel10=1
    Pulleymaxvel10=1
    Pulleyratio11=1
    Pulleyminvel11=1
    Pulleymaxvel11=1
    Pulleyratio12=1
    Pulleyminvel12=1
    Pulleymaxvel12=1
    Pulleyratio13=1
    Pulleyminvel13=1
    Pulleymaxvel13=1
    Pulleyratio14=1
    Pulleyminvel14=1
    Pulleymaxvel14=1
    Pulleyratio15=1
    Pulleyminvel15=1
    Pulleymaxvel15=1
    Usepulleys=False
    [Generalsettings]
    Constantvelocitymode=True
    Stopatangle=89
    Lookaheadlines=300
    Softlimitsenable=False
    Homesequence1=Z
    Homesequence2=X
    Homesequence3=Y
    Homesequence4=None
    Homesequence5=None
    Homesequence6=None
    Linearerror=0.03
    Cornerserror=0.03
    USBbuffersize=0.1
    POSDROsdigits=3
    Doontoolchange=0
    MaxLinearaddlenght=1
    MaxLinearunificationlenght=2
    Kernelfreq=0
    SafeZ=1
    G73_backoff=0.4
    Maximisescreenonstartup=False
    Dwellinseconds=False
    Runmodewhenunknowngcode=0
    Softlimitsgcodeprecheck=False
    Precompilemacrosonstartup=False
    Arcradiustolerance=0.1
    ResetG68onfileload=False
    ResetG51onfileload=False
    [IOsetupsettings]
    Estoppinnumber=11
    Estoppinnegate=False
    Probepinnumber=10
    Probepinnegate=True
    Chargepumppinnumber=0
    Chargepumppinnegate=False
    Chargepumplasermodeon=False
    Chargepumpalwayson=False
    CurrentHiLopinnumber=0
    CurrentHiLopinnegate=False
    Indexpinnumber=0
    Indexprescaler=1
    THCenable=False
    THConpin=0
    THConpinnegate=False
    THCuppin=0
    THCuppinnegate=False
    THCdownpin=0
    THCdownpinnegate=False
    THCmin=0.2
    THCmax=1
    THCfeed=39.996
    THCalwayson=False
    THCondelay=0
    Estopportnumber=1
    Chargepumpportnumber=0
    CurrentHiLoportnumber=0
    Indexportnumber=0
    Probeportnumber=1
    THConport=0
    THCupport=0
    THCdownport=0
    MPG1pinA=0
    MPG1pinB=0
    MPG1portA=0
    MPG1portB=0
    MPG1prescaler=1
    MPG1filter=10
    MPG1speedmultiplier=10
    FROchannel=0
    SROchannel=0
    JROchannel=0
    FROminpercent=0
    FROmaxpercent=0
    SROminpercent=0
    SROmaxpercent=0
    JROminpercent=0
    JROmaxpercent=0
    SPPWMchannel=0
    Ana1invarnum=0
    Ana2invarnum=0
    Ana1outvarnum=0
    Ana2outvarnum=0
    MPG1attachtoJRO=False
    Laseroutputpinnumber=0
    Laseroutputportnumber=0
    Laseroutputpinnegate=False
    THCantidiveenable=False
    THCantidivepercent=0
    Plasmapierceheight=0
    Chargepump2pinnumber=0
    Chargepump2portnumber=0
    Chargepump2pinnegate=False
    Probepin2number=0
    Probeport2number=0
    Probepin2negate=False
    THCdelayenable=False
    THCenableoutpin=0
    THCenableoutport=0
    THCenableoutpinnegate=False
    THCantidiveoutpin=0
    THCantidiveoutport=0
    THCantidiveoutpinnegate=False
    THCantidownoutpin=0
    THCantidownoutport=0
    THCantidownoutpinnegate=False
    THCantidownenable=False
    Ana3invarnum=0
    Ana4invarnum=0
    Ana3outvarnum=0
    Ana4outvarnum=0
    [Appearancesetupsettings]
    2DTLCmarker=True
    Viewerundonepathcolor=3381759
    Viewerdonepathcolor=-5374161
    Viewerrapidpathcolor=16711680
    ViewerTCPmarkercolor=16776960
    ViewerBackgroundcolor=0
    Viewerboundariescolor=16777215
    GVgcodecolors=-16777216
    GVmcodecolors=-233
    GVscodecolors=-32513
    GVfcodecolors=-21931
    GVbackgroundcolor=-12698050
    GVactualcodecolor=-16777216
    GVactualcodemidlinescolor=-16777216
    GVnotinterpretedcodecolor=16711680
    GVaxiswordcolor=-8323328
    GVcoordinatecolor=-9250052
    TCPcone=True
    TCPcross=False
    RotateTCPwithplaneselection=True
    Showzeromark=True
    Zeromarkcolor=-16711681
    DROwarningcolor=-65536
    rotationpointmarkcolor=-65536
    Showrotationmark=True
    Showtoolpathboundaries=True
    Highlightcolor=-1
    Showmessageonsoftlimits=True
    ValidateTextfieldsonEnteronly=True
    Disablejogpanelautopopup=True
    ShowtoolpathZzeroplate=False
    ZplateXextents=100
    ZplateYextents=100
    ZplateZposition=0
    ZplateZpositiononbottom=False
    ZplatePlateOpacity=25
    ZplateColor=-65536
    ZplateXgrid=10
    ZplateYgrid=10
    ZplateGridOpacity=25
    ZplateGridColor=-1
    ZplateShowSoftlimits=False
    ZplateSoftlimitsColor=-16711936
    ZplateSoftlimitsOpacity=100
    [Tooltablevalues]
    TooloffsetZ0=0
    TooloffsetZ1=0
    TooloffsetZ2=0
    TooloffsetZ3=0
    TooloffsetZ4=0
    TooloffsetZ5=0
    TooloffsetZ6=0
    TooloffsetZ7=0
    TooloffsetZ8=0
    TooloffsetZ9=0
    TooloffsetZ10=0
    TooloffsetZ11=0
    TooloffsetZ12=0
    TooloffsetZ13=0
    TooloffsetZ14=0
    TooloffsetZ15=0
    TooloffsetZ16=0
    TooloffsetZ17=0
    TooloffsetZ18=0
    TooloffsetZ19=0
    TooloffsetZ20=0
    TooloffsetZ21=0
    TooloffsetZ22=0
    TooloffsetZ23=0
    TooloffsetZ24=0
    TooloffsetZ25=0
    TooloffsetZ26=0
    TooloffsetZ27=0
    TooloffsetZ28=0
    TooloffsetZ29=0
    TooloffsetZ30=0
    TooloffsetZ31=0
    TooloffsetZ32=0
    TooloffsetZ33=0
    TooloffsetZ34=0
    TooloffsetZ35=0
    TooloffsetZ36=0
    TooloffsetZ37=0
    TooloffsetZ38=0
    TooloffsetZ39=0
    TooloffsetZ40=0
    TooloffsetZ41=0
    TooloffsetZ42=0
    TooloffsetZ43=0
    TooloffsetZ44=0
    TooloffsetZ45=0
    TooloffsetZ46=0
    TooloffsetZ47=0
    TooloffsetZ48=0
    TooloffsetZ49=0
    TooloffsetZ50=0
    TooloffsetZ51=0
    TooloffsetZ52=0
    TooloffsetZ53=0
    TooloffsetZ54=0
    TooloffsetZ55=0
    TooloffsetZ56=0
    TooloffsetZ57=0
    TooloffsetZ58=0
    TooloffsetZ59=0
    TooloffsetZ60=0
    TooloffsetZ61=0
    TooloffsetZ62=0
    TooloffsetZ63=0
    TooloffsetZ64=0
    TooloffsetZ65=0
    TooloffsetZ66=0
    TooloffsetZ67=0
    TooloffsetZ68=0
    TooloffsetZ69=0
    TooloffsetZ70=0
    TooloffsetZ71=0
    TooloffsetZ72=0
    TooloffsetZ73=0
    TooloffsetZ74=0
    TooloffsetZ75=0
    TooloffsetZ76=0
    TooloffsetZ77=0
    TooloffsetZ78=0
    TooloffsetZ79=0
    TooloffsetZ80=0
    TooloffsetZ81=0
    TooloffsetZ82=0
    TooloffsetZ83=0
    TooloffsetZ84=0
    TooloffsetZ85=0
    TooloffsetZ86=0
    TooloffsetZ87=0
    TooloffsetZ88=0
    TooloffsetZ89=0
    TooloffsetZ90=0
    TooloffsetZ91=0
    TooloffsetZ92=0
    TooloffsetZ93=0
    TooloffsetZ94=0
    TooloffsetZ95=0
    TooloffsetZ96=0
    [Workoffset_G54]
    WorkoffsetX=9.907798
    WorkoffsetY=6.095344
    WorkoffsetZ=-4.680063
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G55]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G56]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G57]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G58]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G59]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Machinecoords]
    MachinecoordsX=9.907798
    MachinecoordsY=31.86164
    MachinecoordsZ=-1.415469
    MachinecoordsA=0
    MachinecoordsB=0
    MachinecoordsC=0
    [Tooloffsetcoords]
    TooloffsetZ=0
    [Systemmessages]
    Message0=Valid license key was not found! Application will run in demo mode!
    Message1=Firmware update done!
    Message2=No UC100 connection was found! Application will run in demo mode!
    Message3=Firmware update in progress! Please wait and do not close the application...
    Message4=The application lost the connection with the motion controller device. [nl] Check the connection. The application is closing now! [nl] Save offsets?
    Message5=A machine axis position software limit was reached. The axis was now stopped.
    Message6=The reset logic of the software is active! [nl] Remove the reset condition with pressing the blinking reset button on the screen. [nl] If the reset condition cannot be removed can be due to an external e-stop button is pressed in or a limit switch on the machine tool is active. [nl] Please check the Diagnostics page for the input signals condition.
    Message7=The current job workspace is out of the set software limits.[nl] Adjust the softlimits to fit the job extents or disable the softlimits.
    Message8=The axis is disabled. To calibrate this axis enable the axis first.
    Message9=An internal error occured. The application is closing now.
    Message10=Enter a valid distance in absolute value!
    Message11=The calculated steps per value was saved.
    Message12=Please enter valid data.
    Message13=Active fixture:
    Message14=Are you sure you want to close?
    Message15=
    Message16=
    Message17=
    Message18=
    Message19=
    Message20=
    Message21=
    Message22=
    Message23=
    Message24=
    Message25=
    Message26=
    Message27=The Default profile cannot be deleted!
    Message28=File error.Could not delete the profile's macro library!
    Message29=Do you really want to delete the profile :
    Message30=File error.Could not copy default macros to profile!
    Message31=was loaded!
    Message32=The axis calibration makes a measurement to calibrate the steps per units resolution value for the machine axis. To abort and close this window press the cancel button.
    Message33=Mark the current position of the machine axis. Set the distance and the feedrate on this page and press the OK button to make a movement.
    Message34=Measure the travel distance on the machine axis from the previously marked point to the current point. Type the measured value to the field below and press OK.
    Message35=The new steps per value was calculated and written to the below field. To save the new value press OK. The process is then finished.
    Message36=Switch spindle on first
    Message37=Move Z-axis first to safeZ height:
    Message38=Make movement with safeZ to:
    Message39=Start position(Units):
    Message40=Actual steps per Unit:
    Message41=Distance to move(Units):
    Message42=Feed rate(Units/min):
    Message43=Distance measured(Units):
    Message44=Steps per Units calculated value:
    Message45=The software limits is lower than the safeZ height. Execute the command anyways?
    Message46=was created!
    [Hotkeysettings]
    Keycode1=39
    Buttoncode1=147
    Keycode2=37
    Buttoncode2=148
    Keycode3=38
    Buttoncode3=149
    Keycode4=40
    Buttoncode4=150
    Keycode5=33
    Buttoncode5=151
    Keycode6=34
    Buttoncode6=152
    Keycode7=45
    Buttoncode7=153
    Keycode8=46
    Buttoncode8=154
    Keycode9=81
    Buttoncode9=155
    Keycode10=65
    Buttoncode10=156
    Keycode11=87
    Buttoncode11=157
    Keycode12=83
    Buttoncode12=158
    Keycode13=27
    Buttoncode13=130
    Keycode14=0
    Buttoncode14=0
    Keycode15=0
    Buttoncode15=0
    Keycode16=0
    Buttoncode16=0
    Keycode17=0
    Buttoncode17=0
    Keycode18=0
    Buttoncode18=0
    Keycode19=0
    Buttoncode19=0
    Keycode20=0
    Buttoncode20=0
    Keycode21=0
    Buttoncode21=0
    Keycode22=0
    Buttoncode22=0
    Keycode23=0
    Buttoncode23=0
    Keycode24=0
    Buttoncode24=0
    Keycode25=0
    Buttoncode25=0
    Keycode26=0
    Buttoncode26=0
    Keycode27=0
    Buttoncode27=0
    Keycode28=0
    Buttoncode28=0
    Keycode29=0
    Buttoncode29=0
    Keycode30=0
    Buttoncode30=0
    Keycode31=0
    Buttoncode31=0
    Keycode32=0
    Buttoncode32=0
    Keycode33=0
    Buttoncode33=0
    Keycode34=0
    Buttoncode34=0
    Keycode35=0
    Buttoncode35=0
    Keycode36=0
    Buttoncode36=0
    Keycode37=0
    Buttoncode37=0
    Keycode38=0
    Buttoncode38=0
    Keycode39=0
    Buttoncode39=0
    Keycode40=0
    Buttoncode40=0
    Keycode41=0
    Buttoncode41=0
    Keycode42=0
    Buttoncode42=0
    Keycode43=0
    Buttoncode43=0
    Keycode44=0
    Buttoncode44=0
    Keycode45=0
    Buttoncode45=0
    Keycode46=0
    Buttoncode46=0
    Keycode47=0
    Buttoncode47=0
    Keycode48=0
    Buttoncode48=0
    Keycode49=0
    Buttoncode49=0
    Keycode50=0
    Buttoncode50=0
    Keycode51=0
    Buttoncode51=0
    Keycode52=0
    Buttoncode52=0
    Keycode53=0
    Buttoncode53=0
    Keycode54=0
    Buttoncode54=0
    Keycode55=0
    Buttoncode55=0
    Keycode56=0
    Buttoncode56=0
    Keycode57=0
    Buttoncode57=0
    Keycode58=0
    Buttoncode58=0
    Keycode59=0
    Buttoncode59=0
    Keycode60=0
    Buttoncode60=0
    Keycode61=0
    Buttoncode61=0
    Keycode62=0
    Buttoncode62=0
    Keycode63=0
    Buttoncode63=0
    Keycode64=0
    Buttoncode64=0
    Keycode65=0
    Buttoncode65=0
    Keycode66=0
    Buttoncode66=0
    Keycode67=0
    Buttoncode67=0
    Keycode68=0
    Buttoncode68=0
    Keycode69=0
    Buttoncode69=0
    Keycode70=0
    Buttoncode70=0
    Keycode71=0
    Buttoncode71=0
    Keycode72=0
    Buttoncode72=0
    Keycode73=0
    Buttoncode73=0
    Keycode74=0
    Buttoncode74=0
    Keycode75=0
    Buttoncode75=0
    Keycode76=0
    Buttoncode76=0
    Keycode77=0
    Buttoncode77=0
    Keycode78=0
    Buttoncode78=0
    Keycode79=0
    Buttoncode79=0
    Keycode80=0
    Buttoncode80=0
    Keycode81=0
    Buttoncode81=0
    Keycode82=0
    Buttoncode82=0
    Keycode83=0
    Buttoncode83=0
    Keycode84=0
    Buttoncode84=0
    Keycode85=0
    Buttoncode85=0
    Keycode86=0
    Buttoncode86=0
    Keycode87=0
    Buttoncode87=0
    Keycode88=0
    Buttoncode88=0
    Keycode89=0
    Buttoncode89=0
    Keycode90=0
    Buttoncode90=0
    Keycode91=0
    Buttoncode91=0
    Keycode92=0
    Buttoncode92=0
    Keycode93=0
    Buttoncode93=0
    Keycode94=0
    Buttoncode94=0
    Keycode95=0
    Buttoncode95=0
    Keycode96=0
    Buttoncode96=0
    [Inputtriggersettings]
    Pin1=0
    Port1=0
    Buttoncode1=0
    Activelow1=False
    Pin2=0
    Port2=0
    Buttoncode2=0
    Activelow2=False
    Pin3=0
    Port3=0
    Buttoncode3=0
    Activelow3=False
    Pin4=0
    Port4=0
    Buttoncode4=0
    Activelow4=False
    Pin5=0
    Port5=0
    Buttoncode5=0
    Activelow5=False
    Pin6=0
    Port6=0
    Buttoncode6=0
    Activelow6=False
    Pin7=0
    Port7=0
    Buttoncode7=0
    Activelow7=False
    Pin8=0
    Port8=0
    Buttoncode8=0
    Activelow8=False
    Pin9=0
    Port9=0
    Buttoncode9=0
    Activelow9=False
    Pin10=0
    Port10=0
    Buttoncode10=0
    Activelow10=False
    Pin11=0
    Port11=0
    Buttoncode11=0
    Activelow11=False
    Pin12=0
    Port12=0
    Buttoncode12=0
    Activelow12=False
    Pin13=0
    Port13=0
    Buttoncode13=0
    Activelow13=False
    Pin14=0
    Port14=0
    Buttoncode14=0
    Activelow14=False
    Pin15=0
    Port15=0
    Buttoncode15=0
    Activelow15=False
    Pin16=0
    Port16=0
    Buttoncode16=0
    Activelow16=False
    Pin17=0
    Port17=0
    Buttoncode17=0
    Activelow17=False
    Pin18=0
    Port18=0
    Buttoncode18=0
    Activelow18=False
    Pin19=0
    Port19=0
    Buttoncode19=0
    Activelow19=False
    Pin20=0
    Port20=0
    Buttoncode20=0
    Activelow20=False
    Pin21=0
    Port21=0
    Buttoncode21=0
    Activelow21=False
    Pin22=0
    Port22=0
    Buttoncode22=0
    Activelow22=False
    Pin23=0
    Port23=0
    Buttoncode23=0
    Activelow23=False
    Pin24=0
    Port24=0
    Buttoncode24=0
    Activelow24=False
    Pin25=0
    Port25=0
    Buttoncode25=0
    Activelow25=False
    Pin26=0
    Port26=0
    Buttoncode26=0
    Activelow26=False
    Pin27=0
    Port27=0
    Buttoncode27=0
    Activelow27=False
    Pin28=0
    Port28=0
    Buttoncode28=0
    Activelow28=False
    Pin29=0
    Port29=0
    Buttoncode29=0
    Activelow29=False
    Pin30=0
    Port30=0
    Buttoncode30=0
    Activelow30=False
    Pin31=0
    Port31=0
    Buttoncode31=0
    Activelow31=False
    Pin32=0
    Port32=0
    Buttoncode32=0
    Activelow32=False
    Pin33=0
    Port33=0
    Buttoncode33=0
    Activelow33=False
    Pin34=0
    Port34=0
    Buttoncode34=0
    Activelow34=False
    Pin35=0
    Port35=0
    Buttoncode35=0
    Activelow35=False
    Pin36=0
    Port36=0
    Buttoncode36=0
    Activelow36=False
    Pin37=0
    Port37=0
    Buttoncode37=0
    Activelow37=False
    Pin38=0
    Port38=0
    Buttoncode38=0
    Activelow38=False
    Pin39=0
    Port39=0
    Buttoncode39=0
    Activelow39=False
    Pin40=0
    Port40=0
    Buttoncode40=0
    Activelow40=False
    Pin41=0
    Port41=0
    Buttoncode41=0
    Activelow41=False
    Pin42=0
    Port42=0
    Buttoncode42=0
    Activelow42=False
    Pin43=0
    Port43=0
    Buttoncode43=0
    Activelow43=False
    Pin44=0
    Port44=0
    Buttoncode44=0
    Activelow44=False
    Pin45=0
    Port45=0
    Buttoncode45=0
    Activelow45=False
    Pin46=0
    Port46=0
    Buttoncode46=0
    Activelow46=False
    Pin47=0
    Port47=0
    Buttoncode47=0
    Activelow47=False
    Pin48=0
    Port48=0
    Buttoncode48=0
    Activelow48=False
    Pin49=0
    Port49=0
    Buttoncode49=0
    Activelow49=False
    Pin50=0
    Port50=0
    Buttoncode50=0
    Activelow50=False
    Pin51=0
    Port51=0
    Buttoncode51=0
    Activelow51=False
    Pin52=0
    Port52=0
    Buttoncode52=0
    Activelow52=False
    Pin53=0
    Port53=0
    Buttoncode53=0
    Activelow53=False
    Pin54=0
    Port54=0
    Buttoncode54=0
    Activelow54=False
    Pin55=0
    Port55=0
    Buttoncode55=0
    Activelow55=False
    Pin56=0
    Port56=0
    Buttoncode56=0
    Activelow56=False
    Pin57=0
    Port57=0
    Buttoncode57=0
    Activelow57=False
    Pin58=0
    Port58=0
    Buttoncode58=0
    Activelow58=False
    Pin59=0
    Port59=0
    Buttoncode59=0
    Activelow59=False
    Pin60=0
    Port60=0
    Buttoncode60=0
    Activelow60=False
    Pin61=0
    Port61=0
    Buttoncode61=0
    Activelow61=False
    Pin62=0
    Port62=0
    Buttoncode62=0
    Activelow62=False
    Pin63=0
    Port63=0
    Buttoncode63=0
    Activelow63=False
    Pin64=0
    Port64=0
    Buttoncode64=0
    Activelow64=False
    Pin65=0
    Port65=0
    Buttoncode65=0
    Activelow65=False
    Pin66=0
    Port66=0
    Buttoncode66=0
    Activelow66=False
    Pin67=0
    Port67=0
    Buttoncode67=0
    Activelow67=False
    Pin68=0
    Port68=0
    Buttoncode68=0
    Activelow68=False
    Pin69=0
    Port69=0
    Buttoncode69=0
    Activelow69=False
    Pin70=0
    Port70=0
    Buttoncode70=0
    Activelow70=False
    Pin71=0
    Port71=0
    Buttoncode71=0
    Activelow71=False
    Pin72=0
    Port72=0
    Buttoncode72=0
    Activelow72=False
    Pin73=0
    Port73=0
    Buttoncode73=0
    Activelow73=False
    Pin74=0
    Port74=0
    Buttoncode74=0
    Activelow74=False
    Pin75=0
    Port75=0
    Buttoncode75=0
    Activelow75=False
    Pin76=0
    Port76=0
    Buttoncode76=0
    Activelow76=False
    Pin77=0
    Port77=0
    Buttoncode77=0
    Activelow77=False
    Pin78=0
    Port78=0
    Buttoncode78=0
    Activelow78=False
    Pin79=0
    Port79=0
    Buttoncode79=0
    Activelow79=False
    Pin80=0
    Port80=0
    Buttoncode80=0
    Activelow80=False
    Pin81=0
    Port81=0
    Buttoncode81=0
    Activelow81=False
    Pin82=0
    Port82=0
    Buttoncode82=0
    Activelow82=False
    Pin83=0
    Port83=0
    Buttoncode83=0
    Activelow83=False
    Pin84=0
    Port84=0
    Buttoncode84=0
    Activelow84=False
    Pin85=0
    Port85=0
    Buttoncode85=0
    Activelow85=False
    Pin86=0
    Port86=0
    Buttoncode86=0
    Activelow86=False
    Pin87=0
    Port87=0
    Buttoncode87=0
    Activelow87=False
    Pin88=0
    Port88=0
    Buttoncode88=0
    Activelow88=False
    Pin89=0
    Port89=0
    Buttoncode89=0
    Activelow89=False
    Pin90=0
    Port90=0
    Buttoncode90=0
    Activelow90=False
    Pin91=0
    Port91=0
    Buttoncode91=0
    Activelow91=False
    Pin92=0
    Port92=0
    Buttoncode92=0
    Activelow92=False
    Pin93=0
    Port93=0
    Buttoncode93=0
    Activelow93=False
    Pin94=0
    Port94=0
    Buttoncode94=0
    Activelow94=False
    Pin95=0
    Port95=0
    Buttoncode95=0
    Activelow95=False
    Pin96=0
    Port96=0
    Buttoncode96=0
    Activelow96=False
    [Outputtriggersettings]
    Pin1=0
    Port1=0
    LEDcode1=0
    Invert1=False
    Pin2=0
    Port2=0
    LEDcode2=0
    Invert2=False
    Pin3=0
    Port3=0
    LEDcode3=0
    Invert3=False
    Pin4=0
    Port4=0
    LEDcode4=0
    Invert4=False
    Pin5=0
    Port5=0
    LEDcode5=0
    Invert5=False
    Pin6=0
    Port6=0
    LEDcode6=0
    Invert6=False
    Pin7=0
    Port7=0
    LEDcode7=0
    Invert7=False
    Pin8=0
    Port8=0
    LEDcode8=0
    Invert8=False
    Pin9=0
    Port9=0
    LEDcode9=0
    Invert9=False
    Pin10=0
    Port10=0
    LEDcode10=0
    Invert10=False
    Pin11=0
    Port11=0
    LEDcode11=0
    Invert11=False
    Pin12=0
    Port12=0
    LEDcode12=0
    Invert12=False
    Pin13=0
    Port13=0
    LEDcode13=0
    Invert13=False
    Pin14=0
    Port14=0
    LEDcode14=0
    Invert14=False
    Pin15=0
    Port15=0
    LEDcode15=0
    Invert15=False
    Pin16=0
    Port16=0
    LEDcode16=0
    Invert16=False
    Pin17=0
    Port17=0
    LEDcode17=0
    Invert17=False
    Pin18=0
    Port18=0
    LEDcode18=0
    Invert18=False
    Pin19=0
    Port19=0
    LEDcode19=0
    Invert19=False
    Pin20=0
    Port20=0
    LEDcode20=0
    Invert20=False
    Pin21=0
    Port21=0
    LEDcode21=0
    Invert21=False
    Pin22=0
    Port22=0
    LEDcode22=0
    Invert22=False
    Pin23=0
    Port23=0
    LEDcode23=0
    Invert23=False
    Pin24=0
    Port24=0
    LEDcode24=0
    Invert24=False
    Pin25=0
    Port25=0
    LEDcode25=0
    Invert25=False
    Pin26=0
    Port26=0
    LEDcode26=0
    Invert26=False
    Pin27=0
    Port27=0
    LEDcode27=0
    Invert27=False
    Pin28=0
    Port28=0
    LEDcode28=0
    Invert28=False
    Pin29=0
    Port29=0
    LEDcode29=0
    Invert29=False
    Pin30=0
    Port30=0
    LEDcode30=0
    Invert30=False
    Pin31=0
    Port31=0
    LEDcode31=0
    Invert31=False
    Pin32=0
    Port32=0
    LEDcode32=0
    Invert32=False
    Pin33=0
    Port33=0
    LEDcode33=0
    Invert33=False
    Pin34=0
    Port34=0
    LEDcode34=0
    Invert34=False
    Pin35=0
    Port35=0
    LEDcode35=0
    Invert35=False
    Pin36=0
    Port36=0
    LEDcode36=0
    Invert36=False
    Pin37=0
    Port37=0
    LEDcode37=0
    Invert37=False
    Pin38=0
    Port38=0
    LEDcode38=0
    Invert38=False
    Pin39=0
    Port39=0
    LEDcode39=0
    Invert39=False
    Pin40=0
    Port40=0
    LEDcode40=0
    Invert40=False
    Pin41=0
    Port41=0
    LEDcode41=0
    Invert41=False
    Pin42=0
    Port42=0
    LEDcode42=0
    Invert42=False
    Pin43=0
    Port43=0
    LEDcode43=0
    Invert43=False
    Pin44=0
    Port44=0
    LEDcode44=0
    Invert44=False
    Pin45=0
    Port45=0
    LEDcode45=0
    Invert45=False
    Pin46=0
    Port46=0
    LEDcode46=0
    Invert46=False
    Pin47=0
    Port47=0
    LEDcode47=0
    Invert47=False
    Pin48=0
    Port48=0
    LEDcode48=0
    Invert48=False
    Pin49=0
    Port49=0
    LEDcode49=0
    Invert49=False
    Pin50=0
    Port50=0
    LEDcode50=0
    Invert50=False
    Pin51=0
    Port51=0
    LEDcode51=0
    Invert51=False
    Pin52=0
    Port52=0
    LEDcode52=0
    Invert52=False
    Pin53=0
    Port53=0
    LEDcode53=0
    Invert53=False
    Pin54=0
    Port54=0
    LEDcode54=0
    Invert54=False
    Pin55=0
    Port55=0
    LEDcode55=0
    Invert55=False
    Pin56=0
    Port56=0
    LEDcode56=0
    Invert56=False
    Pin57=0
    Port57=0
    LEDcode57=0
    Invert57=False
    Pin58=0
    Port58=0
    LEDcode58=0
    Invert58=False
    Pin59=0
    Port59=0
    LEDcode59=0
    Invert59=False
    Pin60=0
    Port60=0
    LEDcode60=0
    Invert60=False
    Pin61=0
    Port61=0
    LEDcode61=0
    Invert61=False
    Pin62=0
    Port62=0
    LEDcode62=0
    Invert62=False
    Pin63=0
    Port63=0
    LEDcode63=0
    Invert63=False
    Pin64=0
    Port64=0
    LEDcode64=0
    Invert64=False
    Pin65=0
    Port65=0
    LEDcode65=0
    Invert65=False
    Pin66=0
    Port66=0
    LEDcode66=0
    Invert66=False
    Pin67=0
    Port67=0
    LEDcode67=0
    Invert67=False
    Pin68=0
    Port68=0
    LEDcode68=0
    Invert68=False
    Pin69=0
    Port69=0
    LEDcode69=0
    Invert69=False
    Pin70=0
    Port70=0
    LEDcode70=0
    Invert70=False
    Pin71=0
    Port71=0
    LEDcode71=0
    Invert71=False
    Pin72=0
    Port72=0
    LEDcode72=0
    Invert72=False
    Pin73=0
    Port73=0
    LEDcode73=0
    Invert73=False
    Pin74=0
    Port74=0
    LEDcode74=0
    Invert74=False
    Pin75=0
    Port75=0
    LEDcode75=0
    Invert75=False
    Pin76=0
    Port76=0
    LEDcode76=0
    Invert76=False
    Pin77=0
    Port77=0
    LEDcode77=0
    Invert77=False
    Pin78=0
    Port78=0
    LEDcode78=0
    Invert78=False
    Pin79=0
    Port79=0
    LEDcode79=0
    Invert79=False
    Pin80=0
    Port80=0
    LEDcode80=0
    Invert80=False
    Pin81=0
    Port81=0
    LEDcode81=0
    Invert81=False
    Pin82=0
    Port82=0
    LEDcode82=0
    Invert82=False
    Pin83=0
    Port83=0
    LEDcode83=0
    Invert83=False
    Pin84=0
    Port84=0
    LEDcode84=0
    Invert84=False
    Pin85=0
    Port85=0
    LEDcode85=0
    Invert85=False
    Pin86=0
    Port86=0
    LEDcode86=0
    Invert86=False
    Pin87=0
    Port87=0
    LEDcode87=0
    Invert87=False
    Pin88=0
    Port88=0
    LEDcode88=0
    Invert88=False
    Pin89=0
    Port89=0
    LEDcode89=0
    Invert89=False
    Pin90=0
    Port90=0
    LEDcode90=0
    Invert90=False
    Pin91=0
    Port91=0
    LEDcode91=0
    Invert91=False
    Pin92=0
    Port92=0
    LEDcode92=0
    Invert92=False
    Pin93=0
    Port93=0
    LEDcode93=0
    Invert93=False
    Pin94=0
    Port94=0
    LEDcode94=0
    Invert94=False
    Pin95=0
    Port95=0
    LEDcode95=0
    Invert95=False
    Pin96=0
    Port96=0
    LEDcode96=0
    Invert96=False
    [CAMsettings]
    Tooldia=0
    Startdepth=0
    Cutdepth=0
    Cutperpass=0
    SafeZ=0
    Feedrate=0
    Tooloverlap=0
    Plungerate=0
    Spindlespeed=0
    Arctolerance=0.01
    [Laserengraveplugin]
    workpiecewidth=50
    workpieceheight=50
    keepaspectratio=True
    Yscandistance=0.2
    Feedrate=1000
    Originsetting=7
    [Plugins_enabled]
    Debugger.dll=False
    Diagnostics.dll=False
    Laserengrave.dll=False
    Plugintest.dll=False
    Webcamera.dll=False
    Printer3D.dll=False
    UCR200Plugin.dll=False
    Xbox360controller.dll=False
    Scope.dll=False
    AutoLevelerCA.dll=False
    HYPLUGIN.dll=True
    Modbusmaster.dll=False
    UCCNC_OSK.dll=False
    XHC-HB04_pendant.dll=False
    [Plugins_callstartup]
    Debugger.dll=False
    Webcamera.dll=False
    Printer3D.dll=False
    Scope.dll=False
    HYPLUGIN.dll=True
    UCCNC_OSK.dll=False
    [Macroloops]
    Macroloopautorun0=False
    Macroloopnumber0=0
    Macroloopautorun1=False
    Macroloopnumber1=0
    Macroloopautorun2=False
    Macroloopnumber2=0
    Macroloopautorun3=False
    Macroloopnumber3=0
    Macroloopautorun4=False
    Macroloopnumber4=0
    Macroloopautorun5=False
    Macroloopnumber5=0
    Macroloopautorun6=False
    Macroloopnumber6=0
    Macroloopautorun7=False
    Macroloopnumber7=0
    Macroloopautorun8=False
    Macroloopnumber8=0
    Macroloopautorun9=False
    Macroloopnumber9=0
    Macroloopautorun10=False
    Macroloopnumber10=0
    Macroloopautorun11=False
    Macroloopnumber11=0
    Macroloopautorun12=False
    Macroloopnumber12=0
    Macroloopautorun13=False
    Macroloopnumber13=0
    Macroloopautorun14=False
    Macroloopnumber14=0
    Macroloopautorun15=False
    Macroloopnumber15=0
    Macroloopautorun16=False
    Macroloopnumber16=0
    Macroloopautorun17=False
    Macroloopnumber17=0
    Macroloopautorun18=False
    Macroloopnumber18=0
    Macroloopautorun19=False
    Macroloopnumber19=0
    Macroloopautorun20=False
    Macroloopnumber20=0
    Macroloopautorun21=False
    Macroloopnumber21=0
    Macroloopautorun22=False
    Macroloopnumber22=0
    Macroloopautorun23=False
    Macroloopnumber23=0
    Macroloopautorun24=False
    Macroloopnumber24=0
    Macroloopautorun25=False
    Macroloopnumber25=0
    Macroloopautorun26=False
    Macroloopnumber26=0
    Macroloopautorun27=False
    Macroloopnumber27=0
    Macroloopautorun28=False
    Macroloopnumber28=0
    Macroloopautorun29=False
    Macroloopnumber29=0
    Macroloopautorun30=False
    Macroloopnumber30=0
    Macroloopautorun31=False
    Macroloopnumber31=0
    Macroloopautorun32=False
    Macroloopnumber32=0
    Macroloopautorun33=False
    Macroloopnumber33=0
    Macroloopautorun34=False
    Macroloopnumber34=0
    Macroloopautorun35=False
    Macroloopnumber35=0
    Macroloopautorun36=False
    Macroloopnumber36=0
    Macroloopautorun37=False
    Macroloopnumber37=0
    Macroloopautorun38=False
    Macroloopnumber38=0
    Macroloopautorun39=False
    Macroloopnumber39=0
    Macroloopautorun40=False
    Macroloopnumber40=0
    Macroloopautorun41=False
    Macroloopnumber41=0
    Macroloopautorun42=False
    Macroloopnumber42=0
    Macroloopautorun43=False
    Macroloopnumber43=0
    Macroloopautorun44=False
    Macroloopnumber44=0
    Macroloopautorun45=False
    Macroloopnumber45=0
    Macroloopautorun46=False
    Macroloopnumber46=0
    Macroloopautorun47=False
    Macroloopnumber47=0
    [SpindlePIDsettings]
    PIDenable=False
    Kp=1
    Kd=0
    Ki=0.01
    Samplingtime=10
    [AUXencodersettings]
    AUXencoder1pinA=0
    AUXencoder1portA=0
    AUXencoder1pinB=0
    AUXencoder1portB=0
    AUXencoder2pinA=0
    AUXencoder2portA=0
    AUXencoder2pinB=0
    AUXencoder2portB=0
    AUXencoder3pinA=0
    AUXencoder3portA=0
    AUXencoder3pinB=0
    AUXencoder3portB=0
    AUXencoder4pinA=0
    AUXencoder4portA=0
    AUXencoder4pinB=0
    AUXencoder4portB=0
    AUXencoder5pinA=0
    AUXencoder5portA=0
    AUXencoder5pinB=0
    AUXencoder5portB=0
    Aux1Encodercountsper=1
    Aux2Encodercountsper=1
    Aux3Encodercountsper=1
    Aux4Encodercountsper=1
    Aux5Encodercountsper=1
    Aux6Encodercountsper=1
    [Digitizesettings]
    Addaxisnames=False
    Xinclude=True
    Yinclude=True
    Zinclude=True
    Ainclude=False
    Binclude=False
    Cinclude=False
    Commaseparation=False
    Filenametosave=C:\UCCNC\Example_codes\Digitize.txt
    Numberofdigits=4
    Probedia=0
    Clearfilenamewhenfinished=False
    [UserCheckboxes]
    20301=False
    20302=False
    20303=True
    20304=True
    20305=True
    20306=True
    20307=True
    20308=True
    20312=False
    20309=False
    20310=False
    20311=False
    [UserTextfields]
    20333=10.000
    20334=1.000
    20335=3.000
    20336=1.000
    20337=0.100
    20338=0.250
    20339=3.000
    20340=0.000
    20341=0.000
    20342=0.000
    20343=0.0
    20344=0.0
    20345=0.0
    20346=0.0
    20347=0.0
    20348=0.0
    20349=0.0°
    20350=0.0
    20304=-0.5
    20300=1.101
    20301=1.5
    20302=1.5
    20303=1
    20305=0.7500
    20306=10
    20307=10
    20308=-0.5
    20309=1
    20310=5
    20311=10
    20312=25
    20313=50
    20314=100
    20315=0.001
    20316=0.01
    20317=0.10
    20318=0.25
    20319=0.50
    20320=1.00
    20321=1
    20322=49
    20323=-0.5
    20324=49
    20325=1
    20326=-0.5
    20327=49
    20328=49
    20329=-0.5
    20330=0.000
    20331=0.000
    20332=0.000
    20351=6.000
    20352=0.0500
    20353=0.250
    20354=10.0
    20355=1.0
    20356=0.125
    20357=0
    20358=0.0
    [2017JogSpeeds]
    913=100
    2027=0.01
    [Statistics]
    TotalM3s=48
    TotalM4s=0
    TotalM7s=2
    TotalM8s=1
    Totaltimedays=0
    Totaltimehours=2
    Totaltimeminutes=30
    Totaltimeseconds=48
    M3timedays=0
    M3timehours=0
    M3timeminutes=10
    M3timeseconds=45
    M4timedays=0
    M4timehours=0
    M4timeminutes=0
    M4timeseconds=0
    Cyclestimedays=0
    Cyclestimehours=0
    Cyclestimeminutes=0
    Cyclestimeseconds=40
    TotaldistX=374
    TotalcutX=4
    TotaldistY=306
    TotalcutY=3
    TotaldistZ=188
    TotalcutZ=32
    TotaldistA=0
    TotalcutA=0
    TotaldistB=0
    TotalcutB=0
    TotaldistC=0
    TotalcutC=0
    UCdevicetype=UC300ETH_M45
    [Hyplugin]
    Selectedport=COM10
    Selectedbaud=9600
    SelectedFreq=400
    Selectedminrpm=8000
    Selectedmaxrpm=24000
    SactField=
    AmpFeild=
    OnOff=False
    AmpCB=False
  12. #408
    Mar 2003
    For whatever reason, there have been several people here with adapters that worked in Mach that do not work consistently in UCCNC. All of their issues went away when they switched adapters.
