UCCNC Macro sharing - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 66 of 66
Thread: UCCNC Macro sharing
  1. #61
    Apr 2013
    Sweden
    Default Re: UCCNC Macro sharing
    Quote Originally Posted by asuratman View Post
    Do I need to learn all C language or just instruction on above folder ?
    Macro_capability_detailed.htm is a file, not a folder. Click on it and you will see what's in it. Not really instructions, just description of the functions supported by UCCNC. You need much more than that to learn, at least if you define "learning" as equal to knowing something, not just making small simple changes. Macro_capability_detailed.htm is not a teaching aid, it is intended to help those who know how to program, a user guide for programmers.
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
  2. #62
    Sep 2005
    Indonesia
    Thanks Gery and a_camera for the feedback. I just finished installing uccnc on my mill, its working ... Now, I try to program macro to customize my cnc mill, its fun if I can do it myself. UC300ETH combined with UCCNC is good and not complicated.
  3. #63
    Activation process ipdesign's Avatar
    Jun 2018
    Quote Originally Posted by OlfCNC View Post
    I just tested this code on the 1.2022 an it works.
    I correct the line and now work .
    """ System.IO.File.AppendAllText(@"d:\text.txt", text + Environment.NewLine); """
  4. #64
    Member skynetcommander's Avatar
    Mar 2019
    I need help with the mobile/fixed probe setup. I only find x,y coords in m31 part for fixed probe location. Mine is 250 mm above work area. I made it work by setting retraction to this value, but that has to be edited every time. I need a way to add a z in machine to send the second half of the m31 macro for fixed location. How do I provide that
  5. #65
    Mar 2019
    Hey I got your screen working. I had an error caused by my retration not being fast enough. I set feed rate too low. bumped it up and the active probe error went away. this happened even with and end mill not switching probe. probably tiny filings on tip. Nice work!
  6. #66
    Member DakotaSport07's Avatar
    Jun 2020
    Hello Mr. Andy!
    Thank you so much for sharing your Tool Change Probe "Macro". Everything is working perfectly fine.
    I'm new to UCCNC software, and I can't get their tool change probe routines to work.
    So, I'm really happy to have found you!
    Thanks again mr. Andy
UCCNC Macro sharing
UCCNC Macro sharing
