Cincinnati Milacron Avenger 250T power help
Results 1 to 5 of 5
Thread: Cincinnati Milacron Avenger 250T power help
    Member bcg's Avatar
    Nov 2019
    Default Cincinnati Milacron Avenger 250T power help
    So I picked up this CNC Turning Center at an auction today for $160. I don't know if it works but, even if it's totally trashed there's about $1,000 in tooling in it so I figure I can't really lose. The problem I see already though is that my 3 phase generator produces 240/480 at 60Hz and the plate on the machine calls for 230 at 50 Hz so, what are my options? I don't want to spend a ton on something that might not work. What's the risk of hooking it up to 60 Hz power to test it? The control is 110, single phase 60Hz so I'm not going to damage the electronics. I'm assuming it's just the motors that are 3 phase, will power at the wrong frequency cause serious damage?
    Thanks in advance!Cincinnati Milacron Avenger 250T power help-screenshot_20200729-144408-jpg
    Sent from my Pixel 3 using Tapatalk
    Dec 2013
    Default Re: Cincinnati Milacron Avenger 250T power help
    I think you'll be fine. The 3 phase motors (hydraulic pump (if equipped) and coolant pumps should be 50/60 Hz) The spindle and servos are driven with their own drives, so won't even know it is running 60 Hz.
    Jim Dawson
    Sandy, Oregon, USA
    Member bcg's Avatar
    Nov 2019
    Cool, thanks. I'll hook it up and give it a whirl then. Guess I'm not really out much if it blows up.
    I really don't have any use for it, not even sure what I'd use it for honestly. For the price though, I couldn't pass it up. Maybe it runs and I can leverage it into a mill, which I could use. Cincinnati Milacron Avenger 250T power help
    Member machinehop5's Avatar
    Aug 2009
    ...the way things are going ....might need the machine. CiniM's were solid machines. more Photos please.
    DJ
    PS...Get all the paperwork you can from seller...wiring diagrams, software floppys manuals etc
    Member bcg's Avatar
    Nov 2019
    Here are the pics from the auction. I haven’t seen it in person, looks like it’s been outside a while so I don’t have real high hopes that it’s functional.Cincinnati Milacron Avenger 250T power help-adjustments-jpg
