With cycle turning machines I first thought about Weiler
Hello
I will visit the Emo in a few days and have around 7,5 hours to have a look at cycle turning machines.
What exhibitors would you recommend?
Regards
Rainer
Hello
Hall 26 stall G40 and hall 27 stall D45. Emco is represented there.
The machines run with Fagor cycle controller.
Maybe that would be a good alternative for you.
Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
Hello Intex
Do you know the cycle machines from emco?
Are they good? How is the Fagor controller?
Regards
I don’t know the once from Emco but our firm has a Pinacho Taurus with Fagor 8055. Easy to handle and completely sufficient for simple work that are between CNC and conventional.Hello Intex
Regards
There is a text version so you can try out the controller.
Hello
Can you recommend the Pinacho Taurus?
I saw that the firm also has a stall on the EMO.
Maybe I will have a look at it.
Regards Rainer
No, unfortunately not.
There is only a flashing light in the alarm window APC, nothing else...
soundcloud downloader online
