Need Help! Converting turbo cad into a dfx file
Results 1 to 4 of 4
Thread: Converting turbo cad into a dfx file
    Feb 2013
    Default Converting turbo cad into a dfx file
    May 2004
    If it is possible, your program should have a Save As command. See if you can select File Type > DXF. If this function is not available, look to see if your software has an Export function. Read the Help topics for your software. If you are still confused at this point, computers are not in your talent pool. Turn it off and go watch reality television for a few years.
    Oct 2007
    Moroni, if you need any more help with TurboCad go to TurboCAD Forums - Index. It's a very good forum with out any dip's on it.
    Feb 2013
    Default Thank you
    Thank you that helped greatly. Appreciate your help.
