Just In 90 Minutes Crash Course in Mill-Turn Machining
Results 1 to 1 of 1
Thread: 90 Minutes Crash Course in Mill-Turn Machining
    Member PeteRoy's Avatar
    May 2020
    Talking 90 Minutes Crash Course in Mill-Turn Machining
    Register now for the '90 Minutes Crash Course in Mill-Turn Machining' webinar - https://register.gotowebinar.com/reg...gyEhLXrxKisVcU
    Presented by Aju Augustine
    DATE: Friday, 29th October 2021
    TIME: 5:30 IST
    In this webinar, we will see how SolidCAM’s integrated CAD/CAM technology automates the CNC programming process for Mill-Turn machines.
    What is SolidCAM Mill-Turn and what can you do with it?
    Create design model from 2D drawing using SolidWorks
    Create CAM Part definition and define clamping elements
    Generation of turning and milling toolpaths including synchronization of two turrets using Channel Synchronization
    New Toolkit options in SolidCAM 2021
    Component transfer to the sub spindle and completion of the component on the sub spindle
    Simulation of the generated tool paths and collision control using Machine Simulation
    Generation of the NC program for a two-channel Millturn machine See Less
    Attached Thumbnails Attached Thumbnails 90 Minutes Crash Course in Mill-Turn Machining-bd7451a8-ca2d-6eb3-72ed-8f6746a4a047-jpg
    @solidcam
